NEW - Android 6.0.1 Marschmallow - Wasser 64bit Firmware for Beelink R68 with Gigabit LAN, WIFI AP6335
Just installed 4.0.2 final on my beelink I68 with ap6330 wifi chipset. No problems on install. As expected no wifi. Did the fix from tsukaza but wifi is still not working.
WI-FI is trying to start but nothing happens.
edit: when doing some testing I ran the app "USB Host Diagnostic" and dis/reconnect the usb mouse receiver. And now WIFI is workingLast edited by uli-hh; 21 September 2016, 02:52.
installed 4.01 a week ago on my beelink i68 1000M. working great, but there's no Wi-Fi.
i red the thread and did the following fix as suggested:
A. WiFi fix using xplorer as root
TV BOX
1. Using xplorer (root) open root
2. Go to /etc/firmware and locate nvram_AP6335.txt
3. Copy nvram_AP6335.txt to SD card (optional)
5. Rename nvram_AP6335.txt to nvram_AP6335.txt.orig
6. Rename nvram_AP6330.txt to nvram_AP6335.txt
7. Reboot
Wi-Fi did turn on now, but keep reconnecting every 10 sec.
the Wi-Fi icon doesn't show on the top bar next to the clock (only for a second when reconnecting)
also on the infobar the icon stay grayed all the time (unlike the BT icon, when i press it)
looks like this fix isn't working well on the Beelink i68 1000M ver
help would be appreciated...
how do i flash 4.02 without loosing all data?
Hi everyone, before i was using wasser firmware 4.0.1 on my beelink i68 100Mb ap6330 with wifi mod without problems, very very fast, only youtube and radio streaming apps (tune in) audio stuttering (is there any solution for audio stutttering?)
Version 4.0.2 install ok, but the box doesn't start, only boot animation.... i know first boot is long, but i waited for 15 minutes and nothing happens.
greetings from chileMK808B K.I.A.
MK908 Finless ROM 1.7a + Mele F10
CR11S Quickshot V3.1, 720p kernel @1,7GHz, GPU600, DDR720 + Mele F10
MK902 Quickshot V3.1 1080p @1,8 GHz, GPU 600, DDR720 + Mele F10
GT-I9505 OMEGA ROM
Originally posted by bloodgnome View PostDo you guys have problems with sdcards and the wasser 4.0.1?
I get a storage damaged message no matter what sdcard i use.
Android gives me the option to either use the storage internaly or portable which leads to a formated sd in both cases but still i get the damaged storage message.
in a pc or a different android box the sd cards work fine.
Gesendet von meinem thl 5000 mit Tapatalk
I too have this problem. This seems to happen on my R68 Orion as well as my friends R89.
They are both running Wasser's latest Rom. Nothing seems to correct the problem of corrupted storage for long....
My R68 was working fine yesterday after a reinstall of the Rom but not today ...
I will try the R89 now to see if "Corruption" has reared it's ugly head yet again.
I never had this issue on pre MM roms,but it seems MM does often think that memory cards and USB drives are corrupt.
Hope there will be a solution soon.You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Hello, I have the 10/100M version of the orion r68. I tried to update the 1G version (by changing the original kernel and resource img - using andriod tool 2.35), but the update failed (the device w'ont boot). Can someone please upload the original kernel and resource img so i'll be sure that i have the correct files?
By the way, if i upgrade the firmware as is - The device is turning on but there is no Lan connection(Ethernet).
There are currently 2420 users online. 0 members and 2420 guests.
