Mod for Tanix TX5 Pro MiniM8SII and Nexbox A95X COOLEME MB1 X9 Frankenstein Firmware WIP
Originally posted by gtznutz View Post
A5 shows that it is rooted with rootchecker. I have a boot to recovery app that is working but superSU will not install and other apps that require root do not work.Would love to have navigation and notification bars working too.
Trying to gather remote.conf files from /system/etc from stock roms....and clarification on which boxes it works on....
I have remote.conf from Tanix tx pro minim8sii and Nexbox A5 missing nexbox a95x.
Can someone test on the A5. I see drivers here for it?Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by gtznutz View PostWell prahjister you talked me into it. Remote is a no go on A5 but was trying it out with my K400 and now it is stuck in kodi will not exit.so it looks like I will have to flash back to stock.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
I did three finger salute and restarted it . Superuser is working so I seem to have root. Wi-Fi doesn't seem to be working also stuck at turning on I.did get kodi to exit after reboot. I'll keep testing but I really need the remote so I can turn on off.Last edited by gtznutz; 16 August 2016, 07:04.
I still have to add remotes in. I could write an app but a lot of work. I could shell script. But I could also just provide them and just need to copy appropriate one with es file.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Thanks for your reply ... how do i find the info about the wifi chip ? (also, i'm using wired ethernet .. so i'm not really concerned if wifi stops working)
Have no "Stock Firmware" ... but the user vidim reckons this firmware [link below] (in posts #183, #184) is COOLEME Box compatible
Quote: "banggood sent for mini M8S II. Firmware for SKU439943 this is COOLEME TV BOX"
http://freaktab.com/forum/tv-player-...772#post589772
I also, purchased mine from Banggood
http://www.banggood.com/COOLEME-MB1-...p-1063888.html
@prahjister
Haven't found the WiFi Chip info ... but did find the board type[installed Hardware Info App]the COOLEME is a p212 Device/Product/Board {Pictured Below}
So, i'm assuming it is a re-branded Mini M8S II
And if so .... is this statement correct Quote: "The board is p212 (useful if you want to try alternative firmware)"
http://www.cnx-software.com/2016/07/...-6-0-firmware/
There are currently 2923 users online. 1 members and 2922 guests.
