Mod for Tanix TX5 Pro MiniM8SII and Nexbox A95X COOLEME MB1 X9 Frankenstein Firmware WIP
Originally posted by PM+Mickey View PostPrahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by itsmeedoofer View PostHi,
If we are going to look at fixing the auto refresh rate, audiopassthrough in KODI / SPMC would be a nice one to have a go as as well... ;-)
http://forum.kodi.tv/showthread.php?...473#pid2373473Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
I was having a look into this you beat me to it, this should be a fairly easy one to fix next time one of the guys compiles this rom, just an addition into one of the init.rc scripts...
In the mean time you can always run a script to set this at boot using universal.init from the play store (If you have root)
https://play.google.com/store/apps/d...nit.d&hl=en_GBPrahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by prahjister View Post
It is is android settings. I toggled and box still turns off completely.
There is a setting in android settings to turn on automatic frame rate switching...can you test and give feedback. I think it is called playback settings.
Can you confirm that this works on this box with the firmware from first post...I can adjust to make permanent. Please let me know what you do. I don't have hardware to test this. Thank you.
EDIT:- Just read your post properly, I'll flash this and see, but as I said time is limited unfortunately, sorry
Auto-Framerate for KODI or SPMC did not work, no matter what i set in android settings,
Only after changing permissions of /sys/class/display/mode to 666 Auto-Framerate start to work but with problems on my TV,
I will test some other permissions changes today.
Here is some info for further investigations (it is for other amlogic SOC)
I think that problem with my TV is somewhere here
HDMI handshake, resulting in "null edid" in /sys/class/amhdmitx/amhdmitx0/disp_cap
Originally posted by PM+Mickey View PostAuto-Framerate for KODI or SPMC did not work, no matter what i set in android settings,
My MXiii with KitKat that I got AGES ago had the issue with /sys/class/display/mode, you would have thought this would have been fix by now
Yes test with this software. Otherwise useless info... Please test with latest FTMC that way we can report back any issues. .Marshmellow have sdk issues still more so on rochchip 3368 then these so far. 😃Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by scooter2014 View PostYes test with this software. Otherwise useless info... Please test with latest FTMC that way we can report back any issues. .Marshmellow have sdk issues still more so on rochchip 3368 then these so far. 😃Yea I guess it took a while to sort the issues with Lollipop, we are early adopters
No problem double checked wifi with blues and it makes différence with the finger but even more proof was let kodi addon download 700 meg file let it go till it was stable feed then grabbed it at wifi tape shot up 3 times speed tested it 5 times to be sure so know some others have same issue. Ill do mod and pist in another thread.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Also a favor to make sure it is not me...can someone test tx5 pro firmware below..It might just be a fluke but i think wifi was better with this one. This is the original firmware with issues. But i think wifi was better
TX5 pro: https://drive.google.com/open?id=0B-...jZUTFRUSXZjdmc
TX5: https://drive.google.com/open?id=0B-...TF0NEpKSzBFV1k
TX3 pro: https://mega.nz/#!A4UXCBDZ!kzVARNhzy...gPNIqkY1uS1GroPrahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
There are currently 1828 users online. 2 members and 1826 guests.
