Mod for Tanix TX5 Pro MiniM8SII and Nexbox A95X COOLEME MB1 X9 Frankenstein Firmware WIP
Have No Male to Male USB connnector to accomplish Flash INstuctions from comment #104 and #106 is it possible to use SDcard or USB drive with the IMG files to do a FLAsh for the rom needed for the Mini M8 II S905X??....Is there any other way besides connecting to PC via Male to Male USB Connector
Originally posted by prahjister View PostSo tonight on the agenda
replace superuser with supersu
add fix for passthrough for testing
add fix for autorefresh for testing
add init.d
add the remote.conf to img
add update scripts so you don't have to flash brand new every time and pull down from server
Am i missing anything and should I remove the kodi build stuff?
If not, is there any support in hardware/firmware to allow Remote Apps to work. I have olf MK808B whihc is Rockchip and I use RKRemoteControl app on my android phone whihc is good ful functional remote. Is something like that can be added to firmware if hardware/motherboard supports it
Originally posted by matrix777 View PostHave No Male to Male USB connnector to accomplish Flash INstuctions from comment #104 and #106 is it possible to use SDcard or USB drive with the IMG files to do a FLAsh for the rom needed for the Mini M8 II S905X??
Cables are cheap though and will always come in handy.
Originally posted by sunphan View Post
Would remote.conf allow Remote Apps to work on this firmware directly?
I have to stop tonight. Almist done. Working through some kinks. I can't get init.d to work like I have in the past. So far I have to have both su apks to retain root but i think I can just update su but still have to test. The passthrough hack works and stops clipping of spdif out in kodi that is loaded. Spmc it is still present. Hope it works over HDMI passthrough. Framerate gives me a green screen in kodi. Update script is working. Probably tomorrow before I post gota get some sleepPrahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Prahjister, where did you find the firmware.img for Mini M8S II in order to port it over to TX5? I would like to try porting the root over to that firmware. Is it possible to extract a full OTA update and build into an img file?
One issue I'm having, if I watch any 720p stream in Kodi with this firmware and try to stop the video it freezes for a long time and usually Kodi crashes. Doesn't seem to happen with lower quality streams. SPMC 16.4.2 works better but it crashes a lot too.
Is it possible to dump or manually build a firmware.img from these boxes? I've searched high and low for a way to do it and couldn't find anything myself.Last edited by atvbca; 18 August 2016, 08:32.
Originally posted by atvbca View PostPrahjister, where did you find the firmware.img for Mini M8S II in order to port it over to TX5? I would like to try porting the root over to that firmware. Is it possible to extract a full OTA update and build into an img file?
Is it possible to dump or manually build a firmware.img from these boxes? I've searched high and low for a way to do it and couldn't find anything myself.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Can someone test on each box running this command in terminal emulator "su" and"echo 2 >/sys/class/audiodsp/digital_codec". Then go into kodi settings and see if hdmi passthrough works. You have to turn turn it on in Kodi settings. Clipping stopped after doing this.
Also try to see if the command "beep" works. Might need to run beep or any audio sound before su and echo 2 >/sys/class/audiodsp/digital_codec. I had some issue with no sound last night i thought it was the way i was testing. Saw in kodi thread where if any sound was played before the echo command it would work.
Sorry don't think beep command works
Or "tinyplay name.wav" and copy wav file file of your choiceLast edited by prahjister; 18 August 2016, 14:56.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by prahjister View PostCan someone test on each box running this command in terminal emulator "su" and"echo 2 >/sys/class/audiodsp/digital_codec". Then go into kodi settings and see if hdmi passthrough works. You have to turn turn it on in Kodi settings. Clipping stopped after doing this.
Box: Nexbox A95X S905X with "Frankenstein" modded firmware.Last edited by J0hn; 18 August 2016, 16:30.
There are currently 2887 users online. 1 members and 2886 guests.
