Mod for Tanix TX5 Pro MiniM8SII and Nexbox A95X COOLEME MB1 X9 Frankenstein Firmware WIP
I get connected but the when I start the image file, the box shuts/powers down and doesn't reboot / keep going so I get a low power error
I tried different USB, tried power to the box any other idea?
I reset the 805 firmware in the Android setting and retried - still no luck!- but reset all my apps back....
Updated to usb burning 2.0.8... started burning and said success - time to test
Originally posted by tuff350 View PostThanks Joey, I only held the toothpick till recovery booted. I'll try holding it longer till the box is recognized right now.
The first prompt is that it has erased the bootloader at which point you know that you can remove the toothpick.
Originally posted by tuff350 View PostIt was Windows. Apparently Windows updated the drivers. Everything went as expected after I re-installed the tool (and drivers). No remote, no bluetooth,and no wifi so far.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by matrix777 View Postso still these 3 errors remain after a "successul flash"....No remote, no bluetooth,and no wifi so far.????Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by tuff350 View PostYes, Nexbox A95X Amlogic S905X 2G DDR3 RAM 16G eMMC ROM Android 6.0 2.4G+5.0G Dual Band WiFi 4K 60fps Kodi 16.1 Bluetooth 4.0 HDR VP9 H.265 HEVC Android TV Box Mini PC.
The remote from one of my MXQ's works with it now.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
I plugged in ethernet cable after wifi failed, and tried a few remotes till I found one working with it and my phone doesn't find the bluetooth(but it says that its on) and the box doesn't find any bluetooth( bluetooth is on in my PC and phone both are discoverable. No location service without wifi, bluetooth, or gps.
Originally posted by tuff350 View PostI plugged in ethernet cable after wifi failed, and tried a few remotes till I found one working with it and my phone doesn't find the bluetooth(but it says that its on) and the box doesn't find any bluetooth( bluetooth is on in my PC and phone both are discoverable. No location service without wifi, bluetooth, or gps.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
There are currently 2496 users online. 0 members and 2496 guests.
