Mod for Tanix TX5 Pro MiniM8SII and Nexbox A95X COOLEME MB1 X9 Frankenstein Firmware WIP
which exact numbered posts there have been more than one with varying results for root access for flashing Mini M8 II S905X....i have held off due to still pondering to ship these devices back they are not for me personally else wouldve attempted a flashing days ago which is the best listed posts prior to #400 that has the best firmware tested and modified
Just ran a full test of the latest ROM on the TX5 Pro and everything that is supposed to work does work.
I did have to update the SU binaries, which from memory I didn't remember having to do with the previous version but not an issue.
saw this comment on xda-developers "There is a rooted firmware on freektab by Prahjister that is a Frankenstein build (cross between a mini M8 ll and a Tanix X5). Everything works except you cannot put it in to standby with the remote (it just powers off) and you can not power on with the remote." does this mean all remotes cannot turn the box off?? or just the stock remotes and which thread is the "Frankenstein Build" #wise Post#?????
Originally posted by matrix777 View Postsaw this comment on xda-developers "There is a rooted firmware on freektab by Prahjister that is a Frankenstein build (cross between a mini M8 ll and a Tanix X5). Everything works except you cannot put it in to standby with the remote (it just powers off) and you can not power on with the remote." does this mean all remotes cannot turn the box off?? or just the stock remotes and which thread is the "Frankenstein Build" #wise Post#?????
I figured out how to edit those img that if you modify gets stuck at boot logo. I was also able to root as well. At least it works on a95x 1/8..actually to tell you the truth it might have been rooted already. I never fired up stock....i did notice that it doesnt have the enter issuePrahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
There are currently 2057 users online. 2 members and 2055 guests.
