Mod for Tanix TX5 Pro MiniM8SII and Nexbox A95X COOLEME MB1 X9 Frankenstein Firmware WIP
I've been reading all 32 pages, i have just recently bought the mini m8s ii and would love to root it, or simply install this frankenstein firmware to combat this.
I've not a clue on where to start, thou i know i need the usb burning tool which i have v2.8.
I hate asking as like to read first and try and do it myself, but i am lost here.
I see there is a tut on first page, i assume i am safe to follow this? but there is no info on how to connect box to pc etc in order to flash.
Sorry to be a noob, i appreciate any guidance
Originally posted by scooter2014 View PostThe desc text sets size but photos should be the same suze as the resolution your trying to use.
The image sizes in the stock are 580 x 152 as well as the desc.
i got an early version of a boot but have 2 issues.
1. its huge in size because of filing the screen.
2. it wont play. not sure why its not working.
please if anyone can fix this, go ahead and do it.
https://mega.nz/#!h0QSGIzZ!GDIUKQAmN...2_jqrwpHyXD2WQ
heres the orginal clip i was trying to use if that helps
Not sure why it works on a tablet with lollipop but not the box.Last edited by esloudan; 30 August 2016, 01:51.
Hi Guys,
Finally had a bit of time and got this installed on my M8 Mini II...
Most of Sunday was spend trying to get USB Burning Tool to work with the Mini, that was a real battle of wills but I got there.
Not had chance to play too much, but I will test Passthrough and Refresh Rate Switching during the week.
I have noticed though that I still have the language re-set bug, I know this was highlighted as an issue previously but wasnt sure if it was thought to have been fixed.
The power button still turns the device off despite what is set in the power button settings, I think that is a known though...
As an observation, and I know a lot of this will be down to personal preference, but would SPMC not be better than Kodi as a preinstalled player ? I only say this because it seems to be more Android / AMLogic friendly that Kodi is at the moment...
Also I’ve been using Apex Launcher on my boxes up until now, is there any great difference between the two or is it personal preference again J
Other than that, looks great, no bloat, loads quickly, no speed issues so far over Ethernet..... Great work !
Also Ive been using Apex Launcher on my boxes up until now, is there any great difference between the two or is it personal preference again J
Other than that, looks great, no bloat, loads quickly, no speed issues so far over Ethernet..... Great work !Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
@prahjister
Can someone please give some clear installation steps?
Do we just need to download the file given in the post # 1 on the box and run su update using Terminal?
Is there anything more to it? How would the update script be invoked without knowing where it is and the place where the downloaded ROM file is?
Download burning tool and drivers here install drivers and open tool. Select the firmware you downloaded and unzipped and it will load into the tool. Once completed press Start. Press and hold the reset button and plug in usb to outside port on device. It will connect and install and provide staus as it installs.
If its not connecting check usb port is the right one.
Or check that drivers properly installed.
Once it shows 100 percent in tool stop it and disconnect your device and power up and connect to tv.
Regards.
You can google amilogic burning tool on youtube will show more detail.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by esloudan View PostMade a new bootanimation and its working.
Video and boot zip links
Video Here
Zip Here
https://mega.nz/#!MwwnTSoL!wkLUc645f...IkdpUFlp27HTawPrahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
There are currently 4925 users online. 2 members and 4923 guests.
