Mod for Tanix TX5 Pro MiniM8SII and Nexbox A95X COOLEME MB1 X9 Frankenstein Firmware WIP
Originally posted by Krisshin View Post
According to Redskull@youtube review shows that TX5 pro orig. F/W speed is alot faster..
[ATTACH=CONFIG]n596081[/ATTACH]
I was getting similar rates for high speed cards from both stock and modded.
Originally posted by Krisshin View PostHi, After juggling with Tanix TX5 Pro and Mini M8S II, here are my findings;
1. Mini M8S II: BT does not work.
2. Both: pop-up confirmation panel in some apps are not clickable.
3. Both: some apps disappear in orath application screen, but reappear after removing Nova launcher.
4. Both: MicroSD card 32G(UHS-I or class 10 speed) read/write speed is slow as attached.
I didn't test it with orig F/W, so I am not sure if it's the same or not..
[ATTACH=CONFIG]n595976[/ATTACH] [ATTACH=CONFIG]n595975[/ATTACH]
just replace files in folder bluetooth in " system\etc\bluetooth " Do not forget to change permission of files
reboot and bluetooth work
Could you tell me or point me to a direction how to give permission to those files?
Thank you for your help.
and from there, select the permissions you wish to apply
hint: to see what a permission looks like ... on your PC google eg. 644 permission ... then click "images"
eg.
Originally posted by JoeySmyth View Post
This might be easier to understand ... using ES File Explorer app, "check" the file with a tick ☑ ... then at the bottom right of screen where it says "More" click the 3 vectical dots and select "Properties"
eg.
I just tried to change permission as per ur guide, but there is no option to change them. It only shows permission stat..Last edited by Krisshin; 13 September 2016, 11:11.
Originally posted by JoeySmyth View PostHave you activated "Root Explorer" in ES File Explorer ? .... it's under "Tools"
Then tick (check) the file you want to change permissions .. then "More" and "Properties" and then finally "Permissions ... "Change"
Thank you for snapshots and everything!
Hi all
Firstly thank you very much to prahjister and the others on this thread that have contributed so much to a working rooted ROM and instructions for mildly incompetent users such as me!
I just loaded this onto my Mini M8S II and so far so good. Still need to test bluetooth and some other bits, but the main reason I wanted this was root, xposed etc and that's all up and running.
Unfortunately my amazon app, which was sort of working on the stock ROM is no longer working which is annoying and I was hoping that I could get my hotstar app to work but that is proving more tricky, still that is probably for the main forum and not a ROM specific issue.
Cheers again!
There are currently 5084 users online. 1 members and 5083 guests.
