Mod for Tanix TX5 Pro MiniM8SII and Nexbox A95X COOLEME MB1 X9 Frankenstein Firmware WIP
i made a new rom combining nexbox A95X and Mini M8 SII firmwares
mainly i have put the /system folders of the M8SII on the A95X but including the original /etc folder with bluetooth and wifi drivers for my device
now i'm testing it since 1 hour, i fixed the remote with the right .conf file and i haven't found any problem.
if all is fine i may share it on the forum if it is not against any rule.
Originally posted by lothian77 View Posti made a new rom combining nexbox A95X and Mini M8 SII firmwares
for the language just change the build.prop the harbor MINIM8sII to Tanix TX5 Pro by that of for the language just change the build.prop the harbor MINIM8sII to Tanix TX5 Pro by that of
original mini m8sii after all updates+ota MINIM8SII fixLanguageMayChange111 https://drive.google.com/file/d/0B-o...tQY2FIUFk/view
I did it on my 3 MINIM8sII
to copy and paste on a sd card of the build.prop MINIM8sII use ES File Explorer Pro
Firmware Update Mini M8S II 4K Smart TV Box Amlogic S905X 2/8 Go WiFi LAN 10/100 BT
pour la langue juste changer le build.prop les MINIM8sII port to Tanix TX5 Pro par celle de
original mini m8sii after all updates +ota MINIM8SII fixLanguageMayChange111 https://drive.google.com/file/d/0B-o...tQY2FIUFk/view
I did it on my 3 MINIM8sIILast edited by totor54; 27 September 2016, 17:02.
Originally posted by lothian77 View Postthere are no pins 29 and 30 in my flash
checking datasheet of my emcc i discovered that the 2 pins to short are the ones in the red rectangle in the back of the motherboardPrahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
There are currently 3043 users online. 0 members and 3043 guests.
