Mod for Tanix TX5 Pro MiniM8SII and Nexbox A95X COOLEME MB1 X9 Frankenstein Firmware WIP
Well if the same firmware acts differently on a genuine box and a clone then I would be looking at the clone board and comparing it to a genuine model to see what differences there may be.
If the same, then it does seem to imply some form of hardware issue.
Originally posted by bluesmanuk View PostWell if the same firmware acts differently on a genuine box and a clone then I would be looking at the clone board and comparing it to a genuine model to see what differences there may be.
edit: After exporting the log via terminal i can see this:
- My wifi is keeping enable/disabled, every 0.5segs even when im using cable.
After rebooting and disabling my wifi, and then plug the ethernet, i get 95Mbps again.Last edited by Shepard06; 22 September 2016, 00:28.
Originally posted by KMetal View PostHi prahjister thanks for your work! This firmware is so good! I have a question about customize link of oranth launcher. How it's possibile? If i click "file browser" it reboot launcher, and if I click Browser (with crome icon) il launch stock browser not Chrome Browser. Thanks
PS: please update if possibile 1^tread with bluetooth file fix (by TX5 not pro) for M8s II (or Cooleme). I've read 42 page to find it! thanks
At this point in time is it safe to say that everything is working ok with this rom mod on tx5 pro? I want to order 10 of these and do a nandriod recovery to these boxes. does the rom have all the fixes built in or do i have to do it manually than nandroid backup? meaning keyboard enter fix, brightness fix. passthrough fix. ect... Anything new with auto refresh rate? Basically i just want a decent box for family and friends. I'm using a sub $30 mxq pro 1gb 8gb android 5.1 box and it works pretty damn good. but i want to future proof it for them and myself with latest android 6.0 and new features s905x. I got a good quote for tx5 pro at $34 a piece. should i pull the trigger on this or wait?
Originally posted by sandog View PostWill this firmware work on a Nexbox A5 2/16 box
The only issues are as follows:
1. Initially your stock IR remote won't work and you'll have to replace remote.conf file at this location "system\etc" once the rom is installed. remote.conf for nexbox a5 is provided at "system\remote\nexboxa5" this will partially fix the remote now as home button won't work until you remap key 102 HOME to key 172 HOME in Vendor_0001_Product_0001.kl file
2. The "KODI" & "CloudTV" button on the remote also doesn't work. I tried remapping it but doesn't work as of yet.
3. The power button puts the box to deep sleep and there is no way to wake up the box except unplugging and plugging the power back in. not sure when that will be fixed
Overall this rom is better than stock rom pretty smooth no bloatware
Originally posted by androjohn View Post
yes this works on Nexbox A5 2/16.
Overall this rom is better than stock rom pretty smooth no bloatwarePrahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
There are currently 41530 users online. 1 members and 41529 guests.
