Mod for Tanix TX5 Pro MiniM8SII and Nexbox A95X COOLEME MB1 X9 Frankenstein Firmware WIP
    Originally posted by prahjister View Post
    I might have a solution to your kodi button. I have an app on kb2 that can Map buttons but have to see how it works
    I just tried this app "Multilanguage Keymap Redefiner" and it works. I mapped KODI and several other buttons successfully but app needs to be kept running in the background. I was thinking of a way to actually learn what app does in background so that i could possible create a kl file accordingly. I have attached a screenshot on how it looks in the app i seem to understand what its doing in the background for all other keys except kodi
    i tried changing
    key 390 MEDIA_PLAY_PAUSE
    key 122 MEDIA_REWIND
    key 123 MEDIA_FAST_FORWARD
    All the above worked
    For KODI i tried key 394 KODI just like in stock rom. it didn't work infact none of the keys in remote work when i add this line
    Also any idea when there will be a fix for Power button deep sleep issue ?
    Thanks for your help in advance
      Is there a way to make the kodi icon launch spmc
      Nvidia Sheild Tv
      ADT-1 Developer Kit
      Wetek Core
      Fire Tv2
      Beelink GT1
      Raspberry Pi2
      Odroid C2
      Nexbox A5
        yes replace spmc icon with kodi icon. should work
          Do I use the usb tool to flash? I have twrp for recovery
          Update: USB tool worked
          Nvidia Sheild Tv
          ADT-1 Developer Kit
          Wetek Core
          Fire Tv2
          Beelink GT1
          Raspberry Pi2
          Odroid C2
          Nexbox A5
            Originally posted by androjohn View Post
            yes this works on Nexbox A5 2/16.
            The only issues are as follows:
            1. Initially your stock IR remote won't work and you'll have to replace remote.conf file at this location "system\etc" once the rom is installed. remote.conf for nexbox a5 is provided at "system\remote\nexboxa5" this will partially fix the remote now as home button won't work until you remap key 102 HOME to key 172 HOME in Vendor_0001_Product_0001.kl file
            2. The "KODI" & "CloudTV" button on the remote also doesn't work. I tried remapping it but doesn't work as of yet.
            3. The power button puts the box to deep sleep and there is no way to wake up the box except unplugging and plugging the power back in. not sure when that will be fixed
            Overall this rom is better than stock rom pretty smooth no bloatware
            Was there any issue with brightness on theis rom installed on a A5
            Nvidia Sheild Tv
            ADT-1 Developer Kit
            Wetek Core
            Fire Tv2
            Beelink GT1
            Raspberry Pi2
            Odroid C2
            Nexbox A5
              Hi Prahjister,
              After tested the Franken firmware, I found an issue related with backing up through TWRP.
              After backup, and when try to restore found that the system partition always shows problems in restoring,
              The other two partitions, (Boot and Data), restores without any problems, only the system partition shows this issue and always stop with the infamous error: "extractTarFork() process ended with ERROR=255"
              I also tried replicate this situation with other Roms, (Stock, and Stock-rooted), without any problems, all of them restored successfully !
              Only with the Franken rom this issue appears...
              To avoid any possible doubts, I repeated this process with two different roms, (Franken and Stock Rom), for ten consecutive times, and always with the same results:
              1 - Stock ROM restored always all partitions successfully.
              2 - Franken ROM only restored DATA and BOOT partitions successfully, but the system partition always failed to restore, showing every time the same error: "extractTarFork() process ended with ERROR=255"
              I would like to know if you or somebody else has the same problem.
              It seems that the Franken ROM system partition shows some kind of problem.
              Can you please have a look on it ?
              Waiting for your judgement...
                Is there a way to change the default chinese language to english
                Update: Found it
                Still trying to remap kodi and other icons on the home screen..
                Nvidia Sheild Tv
                ADT-1 Developer Kit
                Wetek Core
                Fire Tv2
                Beelink GT1
                Raspberry Pi2
                Odroid C2
                Nexbox A5
                  i also have a problem with language... at every reboot the language is set to an asian language (i think korean)
                  what can i do?
                  nexbox a95x
                    what can i do?
                    nexbox a95x
                    Go to Settings, More Settings look for the Globe Icon, Then the first row is the Language
                    Nvidia Sheild Tv
                    ADT-1 Developer Kit
                    Wetek Core
                    Fire Tv2
                    Beelink GT1
                    Raspberry Pi2
                    Odroid C2
                    Nexbox A5
                      ok, let's say i have done it
                      now i reboot and i have again korean... what should i now? ))
                      at every reboot the language is back to the last language in the list of languages
                        There is one more thing in the settings about japanese something or orther in there turn it off
                        Nvidia Sheild Tv
                        ADT-1 Developer Kit
                        Wetek Core
                        Fire Tv2
                        Beelink GT1
                        Raspberry Pi2
                        Odroid C2
                        Nexbox A5
                          i put back the stock one now.
                          this thing and the lack of remote to turn on the device has made me decide i'm sorry...
                          is there a way to just mod the stock rom to have root, navbar and notifications?
                            [QUOTE=lothian77;n599554]i put back the stock one now.
                            is there a way to just mod the stock rom to have root, navbar and notifications?[/QUOT
                            If you have a Nexbox A5 look at post 705 about remote issue
                            Get a 20 dollar or less dollar air mouse .. Its the best money you ever spent
                            Nvidia Sheild Tv
                            ADT-1 Developer Kit
                            Wetek Core
                            Fire Tv2
                            Beelink GT1
                            Raspberry Pi2
                            Odroid C2
                            Nexbox A5
                              please sandog, don't take my message as offense, but if you read well my messages before answering you can give me a better answer.
                              i wrote that my problem with remote is to turn ON device and, as is written in post 705, this is impossibile with this rom, while it is possible to turn device OFF.
                              as written in the previous message that you answered, i have a nexbox A95X but same with the remote problem.
                              thanks anyway for your answers...
                              but i ask again:
                              is there a way to just mod the stock rom to have root, navbar and notifications on nexbox A95X?
                                but i ask again:
                                Not that I'm aware of.. Maybe someone else can answer
                                Nvidia Sheild Tv
                                ADT-1 Developer Kit
                                Wetek Core
                                Fire Tv2
                                Beelink GT1
                                Raspberry Pi2
                                Odroid C2
                                Nexbox A5
