what is needed to port / add those settings into Frank?
Mod for Tanix TX5 Pro MiniM8SII and Nexbox A95X COOLEME MB1 X9 Frankenstein Firmware WIP
I'll check kernel and see if that is the difference. Take me some time. Working on another project right now. I will push an update if that is the difference. It should be in kernelPrahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by prahjister View PostI'll check kernel and see if that is the difference. Take me some time. Working on another project right now. I will push an update if that is the difference. It should be in kernel**SkystreamX4 (S802)....M8S (S812)....Mini M8S (S905)....Nexbox A95x (S905x)
Anyone know the proper way of getting nexbox A5 in 2 recovery to sub flash... I hold the button while plug in usb the first one on the side toward the rear of the box it, it gets to the boot logo and freezes every time..Nvidia Sheild Tv
ADT-1 Developer Kit
Wetek Core
Fire Tv2
Beelink GT1
Raspberry Pi2
Odroid C2
Nexbox A5
I flashed two times my box with Amlogic Burning Tool but each time I didn't figured how to do it properly.
I noticed that if the box blue light turn on, after some seconds it disconnects and the flash fails. Instead when the light remains off but it's recognized by the Tool, the flash procedure will complete. I found that pressing the Start button before connecting the usb cable helped somehow.
Originally posted by BubuXP View PostI flashed two times my box with Amlogic Burning Tool but each time I didn't figured how to do it properly.
I noticed that if the box blue light turn on, after some seconds it disconnects and the flash fails. Instead when the light remains off but it's recognized by the Tool, the flash procedure will complete. I found that pressing the Start button before connecting the usb cable helped somehow.Nvidia Sheild Tv
ADT-1 Developer Kit
Wetek Core
Fire Tv2
Beelink GT1
Raspberry Pi2
Odroid C2
Nexbox A5
Originally posted by androjohn View PostHi, Firstly i wanted to appreciate the work you're doing. Great work on Mod for Tanix Pro i recently installed it on my Nexbox A5 2G/16G and its working perfectly. Root is working fine too. Great ROM. The only issue i am having is that stock remote is not working. Is there any way we could get it to work again ? Any help would be much appreciated
Sent from my SM-N910W8 using Tapatalk
Only 2 issues now are:
1. Power button button shuts down the box instead of sleep so it doesn't wake up until you unplug and plug back in. (any idea which file to mod in order to fix it?)
2. Home button doesn't work on the remote
Thanks a lot for this. Installed it on my Mini M8S II and it's working perfectly.
What lead me to install this ROM was the passthrough issue. Sound wasn't stable at all when using 5.1 passthrough on Kodi.
Without the Passthrough Fix, same thing happens. The audio ducks every two seconds.
With the passthrough fix, the audio works fine for some time and then it becomes distorted and full of noise.
Is the passthrough fix for the M8S II?
Is it supposed to fix the ducking or other thing?
How do I disable the fix?
Originally posted by sandog View Post
Did you hold the power down before pluging in usb to start to flash
And remember that the box should be disconnected from every other cable (power, HDMI, etc.) before flashing.
I didn't tried yet, but you could flash the Frankenstein ROM .img from TWRP.
Read in my other post how to start and/or install TWRP:
Using the same procedure described there you can try to install the firmware .img file, it should be less stressing than flashing via Windows.
Yes, I hold down the hidden button inside the little hole, under the box. That is called the reset button.
Using the same procedure described there you can try to install the firmware .img file, it should be less stressing than flashing via Windows.Nvidia Sheild Tv
ADT-1 Developer Kit
Wetek Core
Fire Tv2
Beelink GT1
Raspberry Pi2
Odroid C2
Nexbox A5
Originally posted by dastinger View PostThanks a lot for this. Installed it on my Mini M8S II and it's working perfectly.
Is there a ver of twrp that will work on the nexbox A5 also can anything be done to make the usb stay on when in sleep mode because if you have a usb mouse or keyboard plugged in the unit will not wakeNvidia Sheild Tv
ADT-1 Developer Kit
Wetek Core
Fire Tv2
Beelink GT1
Raspberry Pi2
Odroid C2
Nexbox A5
There are currently 3825 users online. 0 members and 3825 guests.
