Mod for Tanix TX5 Pro MiniM8SII and Nexbox A95X COOLEME MB1 X9 Frankenstein Firmware WIP
Originally posted by JoeySmyth View PostMy COOLEME MB1 Bluetooth Issue is resolved (should have been using Tanix TX5 [not Pro] firmware) also have Root
http://freaktab.com/forum/tv-player-...755#post594755
[QUOTE=gtznutz;n594816]
My A5 has been flashed at least 20 times and I have never unpluged HDMI cable. If it doesn't flash first time I just unplug USB cable and replug it without stopping the burnning tool. It seems that the driver doesn't always work the first time.[/Q
I tried flashing it 30 times and it wouldnt go.. I would hold the recovery button down plug in the usb and everytime it would get hung up on the boot logo it would connect on the usb tool while being stuck on the boot logo. I would let go of the push button I would hit flash just to try it and it would start the flash and reset the a5 and give a error . I would try holding the button down again, unplugging the usb everything just wouldnt flash.. It was a big pain in the assNvidia Sheild Tv
ADT-1 Developer Kit
Wetek Core
Fire Tv2
Beelink GT1
Raspberry Pi2
Odroid C2
Nexbox A5
[QUOTE=sandog;n594820]Originally posted by gtznutz View Post
I tried flashing it 30 times and it wouldnt go.. I would hold the recovery button down plug in the usb and everytime it would get hung up on the boot logo it would connect on the usb tool while being stuck on the boot logo. I would let go of the push button I would hit flash just to try it and it would start the flash and reset the a5 and give a error . I would try holding the button down again, unplugging the usb everything just wouldnt flash.. It was a big pain in the assLast edited by gtznutz; 05 September 2016, 15:26.
Hi ! Thanks you for this firmwareRemote work great (except shortcut, its normal ??) after the little trick.
I have an issue with wifi... i see my wifi, can connect, work great but after a reboot, i'm disconnected and i don't see it no more... So i'm stuck without wifi, my computer and phone can connect. I already restart my router. I don't know why it's not working anymore
ps : i can see the other network
Originally posted by WizardPC View PostHi ! Thanks you for this firmwareRemote work great (except shortcut, its normal ??) after the little trick.
Originally posted by sandog View PostIs there a ver of twrp that will work on the nexbox A5 also can anything be done to make the usb stay on when in sleep mode because if you have a usb mouse or keyboard plugged in the unit will not wake
What box are you running? Also have you made sure wi-fi is on and ethernet is turned off and cable disconnected? Don't expect great reception either unless you are going to do the antenna mod.
I have seen others "issues", i'm not enjoying this box for the moment
Shortcut on remote doesn't work
Date/Hours is not set with network, and you can't do it manually with the remote. Moreover after setting it with a mouse, is reset after a reboot...
I don't know if bluetooth work because it can't be see by any remote application i have downloaded on my phone.
Originally posted by androjohn View Post
I recently came across this TWRP Recovery. It works flawlessly you just need to use mouse for it. I have tested it on a Nexbox A5 2G/16G
Nvidia Sheild Tv
ADT-1 Developer Kit
Wetek Core
Fire Tv2
Beelink GT1
Raspberry Pi2
Odroid C2
Nexbox A5
A95X 2/16. Perhaps it's my router, because with my phone (sharing connection) i haven't this problem... I see more than 10 network EXCEPT mine.
Shortcut on the remote, like the Kodi button. Yes correct time zone, but it's not possible to set the date and hours with the remote only...
My wifi issue seems to be gone since i have made a factory reset. Wait and see
I haven't re-tested bluetooth yet (but yes it was paired but none of my application can see the box)
There are currently 1684 users online. 1 members and 1683 guests.
