I have no success to flash this image through recovery (I try to get back to stock firmware) because of several errors, so I looking for stock image for a burning tool.
Mod for Tanix TX5 Pro MiniM8SII and Nexbox A95X COOLEME MB1 X9 Frankenstein Firmware WIP
Originally posted by atvbca View Post
Please share details on how to edit those img files.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by prahjister View PostI figured out how to edit those img that if you modify gets stuck at boot logo. I was also able to root as well. At least it works on a95x 1/8..actually to tell you the truth it might have been rooted already. I never fired up stock....i did notice that it doesnt have the enter issuehopefully it will work on the A5 too.
Some additional info for autoframerate with kodi 16.1
if I manualy (in android settings) select 1080p/24Hz and then change /sys/class/display/mode to 666 and start kodi most of autoframerate playback is ok (some framerate autoselected do not work om my tv).
I found what possibly cause problems
/sys/class/amhdmitx/amhdmitx0/config
disp switch (force or edid): force
audio config: on
probably it must be
disp switch (force or edid): edid
audio config: on
supported modes ov your TV set can be found here
/sys/class/amhdmitx/amhdmitx0/disp_cap
EDID decoded
/sys/class/amhdmitx/amhdmitx0/edid
Audio capabilities
/sys/class/amhdmitx/amhdmitx0/aud_cap
You can read these files with file browser or use terminal and cat command
example
cat /sys/class/amhdmitx/amhdmitx0/edid
Originally posted by PM+Mickey View PostSome additional info for autoframerate with kodi 16.1
audio config: on
probably it must be
audio config: on
EDID decoded
Audio capabilities
example
cat /sys/class/amhdmitx/amhdmitx0/edidPrahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Thanks for advice but this file is constantly overwtitten
Dont have free time for testing but probably will try something like this
create file (/storage/devconfig) with content
audio config: on
and from terminal
mount -o bind /storage/devconfig /sys/class/amhdmitx/amhdmitx0/disp_cap
By the way nexbox post new firmware for the Nexbox A5 they are different for the 1G/8G and 2G/16G dated 160808 & 160806
there is the link http://www.inexbox.com/nexbox-a5-and...d-coming-soon/
prahjister: Testing on the Mini M8S II S905X, I can power the device off and on with the stock remote.
I was finally able to get the factory firmware.img for the Mini M8S II from the manufacturer. I'm having trouble customizing it with the AML Customization Tool though, due to a limit on the size of the system partition (1024M). On the Base Info tab all the partition names and sizes are corrupt. What file do I need to modify to increase the system partition size limit?
Mini M8S II S905X latest stock factory img: https://mega.nz/#!zIgkkBRK!71kyxftMC...pY4saQKb79dJ7o
Originally posted by atvbca View Postprahjister: Testing on the Mini M8S II S905X, I can power the device off and on with the stock remote.
Mini M8S II S905X latest stock factory img: https://mega.nz/#!zIgkkBRK!71kyxftMC...pY4saQKb79dJ7oPrahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by atvbca View PostMini M8S II S905X latest stock factory img: https://mega.nz/#!zIgkkBRK!71kyxftMC...pY4saQKb79dJ7o
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
There are currently 2093 users online. 2 members and 2091 guests.
