Mod for Tanix TX5 Pro MiniM8SII and Nexbox A95X COOLEME MB1 X9 Frankenstein Firmware WIP
Originally posted by prahjister View Post
Originally posted by mallox View Postprahjister there is the feadback so far for that last rom you did
For the Nexbox A5 2G/16G 2.4G/5G Dual band
-remote still not working as expected
-WIFI 2.4G and 5G are working
-BT is working
-and the box is rooted
good jobPrahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Is there a remote file in the etc directory
The remote was working, at least to poweroff, but CANNOT power ON with the remote.
I also try to add the launcher from the A5 that (smart.tv) but screen is just black and it take for ever (10-15 min) for the device to load from the animation.
I try to repack as per your tutorial to add the remote.conf from A5 firmware in etc directory.
I also try to add the launcher from the A5 that (smart.tv) but screen is just black and it take for ever (10-15 min) for the device to load from the animation.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by kalenz View PostHmm, I took page 1 notes as it wouldn't wake from sleep (not that it also wouldn't power on). Maybe that wording should be changed?
I'm almost ready to give this image a try but waiting for final and to see the outcome of your attempt to root the mini.
Mini M8S IIPrahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
With the mod TX5 firmware. Sorry, I thought this thread was about trying to root the original firmware (I should have put my comment there).
Originally posted by kalenz View PostWith the mod TX5 firmware. Sorry, I thought this thread was about trying to root the original firmware.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by prahjister View PostHere it is. I also moved over the one Bluetooth file that was different. (big thanks to gtznuts) Need to really test this all all the boxes...I will test tonight on Tanix TX5 Pro to make sure no issues with it.
I would push this over update script but wifi is needed to do that lol. So hopefully this will be final.
If you can help test need at least these boxes tested. Once tested on all of them I will move to first post. Again thank you gtznuts
Tanix TX5 Pro AP6255
MINIM8SII AP6212
Nexbox A95x 2/8 ????
COOLEME MB1 (remote works with no modification/ Bluetooth doesn't) ???
Nexbox A5 AP6330
Nexbox A95x 2/16 AP6330
http://www.mediafire.com/download/6c..._ProA5Test.zip
Bluetooth ~ Not Working (tried several Bluetooth devices ... they all time-out)
Wi-Fi ~ Working (did'nt test it last time because i'm used wired primarily)
Remote Control ~ Working without any modification
Root Access ~ Working
Originally posted by JoeySmyth View Post
Tested on my COOLEME MB1 ... no difference to the original custom tanix mod eg.
Root Access ~ WorkingPrahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by prahjister View PostOriginal is not rooted?
I get same on mini m8s ii original firmware trying to install SuperSU.
This thread points to TX5 firmware if you want root.
Originally posted by J0hn View Post
prahjister that A5 stock image that is posted here: http://chinagadgetsreviews.com/firmw...l#comment-4640 maybe not official firmware from the vendor of inebox. But, the firmware appears to have the su binary installed but does not load properly for some reason.
There are currently 1975 users online. 3 members and 1972 guests.
