Mod for Tanix TX5 Pro MiniM8SII and Nexbox A95X COOLEME MB1 X9 Frankenstein Firmware WIP
Thanks.
Testing right now and will report back findings.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by bluesmanuk View PostNo clipping on AC3 or DTS, so that works perfectly.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
General quick testing and feedback
Flashing went fine and first boot was faster than normal.
Updated SU binaries and rebooted with no issues. SU working perfectly.
Everything nice and smooth and so far have not had one of the 'unfortunately xx app has closed'
Applied passthrough fix and after reboot waited less than 20 seconds for sound confirmation (takes less than 10 after subsequent reboots)
AC3 and DTS playing without clipping (Kodi/SPMC/MX Player 1.8.6 with AC3 codec)/Stock Movie Player
Kodi video playback also seems just that little bit more fluid than I was seeing before, so the passthrough fix may have had a beneficial outcome elsewhere too. SPMC playback is just that little bit better though.
Ethernet speed excellent and various speed tests performed to confirm.
Android TV Youtube app is laggy with 720p/1080p. Play Store app is much smoother, although not perfect.
Apps permissions for things such as Titanium backup are fine.
Play Store functioning fine.
Bluetooth working fine.
5Ghz AC WiFi working fine and speed test results as before and very satisfactory.
2.4Ghz WiFi seems fine for me but will see what speeds Scooter gets with his space age antenna mod.
Compared to the stock ROM, this is a beauty.
You are a starLast edited by bluesmanuk; 21 August 2016, 08:36.R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Originally posted by prahjister View Post
That is with the fix applied and it was not playing right on other firmware? You can test by rebooting and starting Kodi before the fix is applied to test. If kodi is started before have to reboot and let the fix run again. And do you see DTS on your receiver?
DTS does show on the receiver, so I know for sure that it is DTS (same is true for Dolby)
thanks prahjisteri have a friend his mini m8 ii s905 android 5.0 is fully rooted not sure if that helps im presuming the android 6.0.1 S905x mini m8 ii just needs an OS downgrade and move fwd easier that way i could be wrong...im here learning all i can been stuck with some devices "mini m8 ii 905x" that i ordered for some colleagues and without root privilege...you know how that goes :/...#thanksAMilli #foranythingUDiscoverHelpful
Wow, after reading all 19 pages to this post I realized what great timing that I seem to have, as my new "Nexbox A95X Amlogic S905X 2G DDR3 RAM 16G" just arrived. I will tryout your custom firmware tonight. Thank you EVERYONE for your hard work and experience. I can hardly wait to try it out, but a bit hesitant because Nexbox hasn't released the stock firmware for my box yet. I do have 1 question though, Can anyone recommend a recovery for my box? Has anyone ported TWRP for it?
Originally posted by matrix777 View Postthanks prahjisteri have a friend his mini m8 ii s905 android 5.0 is fully rooted not sure if that helps im presuming the android 6.0.1 S905x mini m8 ii just needs an OS downgrade and move fwd easier that way i could be wrong...im here learning all i can been stuck with some devices "mini m8 ii 905x" that i ordered for some colleagues and without root privilege...you know how that goes :/...#thanksAMilli #foranythingUDiscoverHelpful
No you can't just downgrade Android as you can with Windows.
With your mini m8 ii 905x that you are stuck with, you simply use this firmware and you will have a rooted box that is also a great improvement on the stock ROM.
There are currently 2956 users online. 0 members and 2956 guests.
