Mod for Tanix TX5 Pro MiniM8SII and Nexbox A95X COOLEME MB1 X9 Frankenstein Firmware WIP
Originally posted by zickler View Postjust for info tried this image with the Tanix TX5 Pro. When using passthrough on Kodi, and fast-forwarding the video, sound goes crazy when normal playback is resumed. cured the "kodi has unfortunately stopped" messages though
great work to all involved
Is this passthrough using HDMI or SPDIF?
Also try with SPMC.
Originally posted by gtznutz View PostYou didn't need to take it apart all we need is original rom.besides warranty was already voided by installing custom firmware
at least i know now that "COOLEME" is just a re-branded name for the MiniM8SII
oh, and no, i don't have the original rom (box was not rooted when i bought it)
Has anyone tested this modded firmware with an external USB or USB-RF keyboard? The stock Mini M8S ii 08/05/2016 firmware that I received from Gearbest a few days ago has disabled the ENTER key for some reason. I tested this with one USB wired keyboard and two USB RF keyboards. It is hard to believe that the manufacturer did not test this.
I also noted that AIDA64 indicates that there are both internal USB 2.0 and internal USB 3.0 hubs in the Mini M8S ii SoC but testing shows that they only connected the two USB ports to USB 2.0. I am guessing that USB 3.0 power draw might overheat the device in such a compact enclosure.Last edited by Gooplusplus; 23 August 2016, 04:15.
Originally posted by Gooplusplus View PostHas anyone tested this modded firmware with an external USB or USB-RF keyboard? The stock Mini M8S ii 08/05/2016 firmware that I received from Gearbest a few days ago has disabled the ENTER key for some reason. I tested this with one USB wired keyboard and two USB RF keyboards. It is hard to believe that the manufacturer did not test this.
I also noted that AIDA64 indicates that there are both internal USB 2.0 and internal USB 3.0 hubs in the Mini M8S ii SoC but testing shows that they only connected the two USB ports to USB 2.0. I am guessing that USB 3.0 power draw might overheat the device in such a compact enclosure.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Firmware for NEXBOX A95X (S905X, 2+16G) now available.
from here
http://www.tvboxnews.com/nexbox-a95x...ware-download/
NEXBOX A95X (S905X CPU) Android 6.0 TV Box : 1+8G, 2+8G, 2+16G), the firmwares are different. They have links to all 3 now.
This is the site that Nexbox sends you to for firmware as per Nexbox's page here.
Originally posted by tuff350 View PostFirmware for NEXBOX A95X (S905X, 2+16G) now available.
from here
http://www.inexbox.com/download-andr...x-coming-soon/
Originally posted by meatheadmike View Post
Interestingly they include a version of the mod tool and the burning tool. I wonder if it will be easier to mod this one than the A5 rom? I noticed that the A5 rom will simply boot to recovery if you touch the system stuff. Even just opening it, not changing any fields and repacking results in a boot-to-recovery :-( Now I just have to wait for the painfully long download to finish...Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Hey prahjister Nice work with all this Great stuff
Just wondering if you can make an sd card update flashable zip from this test rom
A friend would like to test it on this box but the box has no recovery button
He has tested the Mini m8s ii sd card stock rom & he did like it apart from no root (Wifi did not work either but he did not mind that)
Originally posted by blinkone View PostHey prahjister Nice work with all this Great stuff
You don't need a recovery button. My a95x s905x 16/2 box doesn't have one. Just plug in the usb cable and immediately hit "start" on the burn tool.Please consider making a Donation to freakTab
There are currently 1570 users online. 1 members and 1569 guests.
