Mod for Tanix TX5 Pro MiniM8SII and Nexbox A95X COOLEME MB1 X9 Frankenstein Firmware WIP
Originally posted by meatheadmike View Post
Stock A5 will work on your box. You just wont have root.
Originally posted by mallox View PostNow I can't go back to stuck firmware. I got this error when flashing:
[12:28:50 437][HUB3-13][Err]--[0x00101004]Erase bootloader/Lowper/Identify/Error result
If someone can helpMany devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by scooter2014 View Post
Which box ? Tanix or A5
And I get same error trying to flash any ROM since flashing the"A5SwapDTB" from prajister.
And I'm using USB2.0 port from my computer, also try an other computer.
Can't try the second port on the device because only the one in the back is recognise by the USB tool.
If you have any suggestion it will be of great help.
If someone can help
Originally posted by prahjister View PostWait a minute what wifi chip does the A5 have? Ap6330? If so I might be able to just swap the dtb file.
A5
Originally posted by gtznutz View Post
I have wi-fi working with the Frankenstein Rom. I used the customization tool and there is one extra folder in system\etc\wifi. It is AP6330. Add that and wi-fi will work. If you need more testing on A5 rom I will when I have time.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
If someone can help
Been there done that. try changing USB ports. Seems that the driver gets fouled up. but keep trying it will work.
It did actually work by letting it start the update. Than when it fail with an error I just had to unplug and replug immediately the USB to the SAME port WITHOUT pressing stop and it will start by itself and work.
I test it twice by reinstalling the "A5SwapDTB" that seem to cause the problem to be sure it wasn't luck.
Now back to stock firmware and ready to test new thing for you guys
There are currently 2979 users online. 0 members and 2979 guests.
