Mod for Tanix TX5 Pro MiniM8SII and Nexbox A95X COOLEME MB1 X9 Frankenstein Firmware WIP
Hi tech-mates thanks for the responses while i was at work any luck verifying if the rom from this thread below works full functioning on Mini M8s II S905X
"We are talking about installing SuperSU v2.76 on prahjister's modded firmware (http://freaktab.com/forum/tv-player-...n-firmware-wip) which is already rooted with Superuser but that doesn't work properly, so you have to install SuperSU over it for a proper working root.Soon prahjister will be replacing Superuser with SuperSU in the rom so you could just wait for him to do that instead of messing with SuperSU yourself."
Im reviewing the responses and pondering if to just wait a lil bit while the brain storming and great efforts so far are at best laid down....I have never ordered a android tv amologic device unrooted and had no idea the 6.0 905x devices would not be.....and i really dont mind being brought up to speed with simple instructions step by step for me to follow to complete a root from the above rom used by "prahjister" or another other working rom to get SuperSU working while bluetooth, wifi, and audio components dont get harmed.
Originally posted by matrix777 View PostHi tech-mates thanks for the responses while i was at work any luck verifying if the rom from this thread below works full functioning on Mini M8s II S905X
sorry got home from work and now trying to play catch up which exact comment has the rom #1 **comment one** should i use that rom or wait for prahjister to do more tweaking is the rom installation process instructions the same even though its Android 6.0....for i.e on older boxes used to do the toothpick/hold down power stuff to get android box to get to bootloader
Originally posted by matrix777 View Postsorry got home from work and now trying to play catch up which exact comment has the rom #1 **comment one** should i use that rom or wait for prahjister to do more tweaking is the rom installation process instructions the same even though its Android 6.0....for i.e on older boxes used to do the toothpick/hold down power stuff to get android box to get to bootloader
Have a read through the thread to decide whether which firmware you want to install based upon comments and feedback so far.
That sounds about right.
I did add the fix for passthrough and autorefresh earlier but got green or corrupt screens when loading Kodi or SPMC.
I would remove the org.xbmc.kodi.zip, which will reduce the size of the ROM and start with a clean install.
It also nods in the direction of not being seen to potentially support the piracy addons.
There are plenty of automated mass install utilities out there for those that want to go down that route.
Might even be worth adding SPMC in as that is the one fork that looks to be getting some specific AMLogic support.
This is why i saud to include Ftmc that way it can be reported back to see if issue can be resolved. I have no serious issues in it now but if someone wants to test the passthrough we can go from there...
Leanback yuk lol .... Limit android when it can be all it can be....
But getting there put together small cheap mod for wifi. Works so ill load it and show how to on it. Just wana finish up few things.... I have boxes everyware and just got the misses telling me if not cleaned up garbage pail treatment comingMany devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
The only potential issue with loading FTMC is that it would have to replace Kodi as the two cannot be used at the same time by default.
FTMC at the moment has the RK codec, so is perhaps more orientated towards Rockchip right now.
I can certainly see the benefit of feedback, especially if there is a possibility of having both codecs available for a more all round future use.
I don't have any strong feelings either way as I would test a number of Kodi and fork builds anyway.
So put me down as a neutral on this one.
Same with launchers as I hate all of the boxy ones that come preinstalled these days, so will always switch to Nova anyway.
Of course it also depends on how many things prahjister wants to do, although we could be sadists and keep him busy forever lol
Might even be worth adding SPMC in as that is the one fork that looks to be getting some specific AMLogic support.Originally posted by bluesmanuk View Post
Might even be worth adding SPMC in as that is the one fork that looks to be getting some specific AMLogic support.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
True we can always remove it if it causes same issues. Blues check with Loius but i think he added all of spmc tweeks for amilogic as well. Have any of you tested passthrough on it? Ive been running it for few dats with no issues but i dont use passthrough.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
There are currently 3681 users online. 0 members and 3681 guests.
