Mod for Tanix TX5 Pro MiniM8SII and Nexbox A95X COOLEME MB1 X9 Frankenstein Firmware WIP
    Originally posted by JoeySmyth View Post
    Apologies for my ignorance ... i am familiar with flashing Rockchip devices (have done it several times)
    I have never flashed Amlogic devices ... so i went searching for a Step-by-Step Guide on how to flash Amlogic Firmware
    Is this one correct ? ... https://www.entertainmentbox.com/how...-burning-tool/
    Or ... if someone could provide me with a link or instructions i would be very grateful
    Apologies again for being a NOOB
    Yes generally that will do the trick.
    What I do is fire up the burning tool, import the firmware and click the start button first.
    Then have one end of my USB cable to the PC.
    Then push a pin into the reset hole on the bottom of the case whilst I insert the USB cable into the port nearest the sd card (TX5 Pro).
    You will then see the software erase the bootloader and start the download, at which point you can remove the pin and let it do it's stuff.
      Originally posted by gtznutz View Post
      My A5 has no power button as well.It was a trick to do. I had to push reset button than connect the power and usb cable at the same time then release reset button.
      For most devices you should not need to use the AC power as the USB cable will deliver enough power to flash on it's own.
        Thanks Bluesman
        doh! just realized i have no Male-to-Male USB leads (got heaps of OTG adaptors but they are all Mirco USB) .... guess i'm going shopping today
          Edit: Already answered.. too slow on the draw haha
            Duplicate post...
              Thanks Bluesman
              You can make one just connect the colors and use some electrical tape
                Ok need someone to preform quick test... Testing wifi think i found the issue after testing and checking the download speeds on same server.... Use something that you know is constant and give you continual reading.
                ​​​​​​run the test with out doing and thing. Then run the test holding the box with two fingers directly even with the power in and logo m8s but 1/2 inch in from the extact oposite of the box (front) Thats where the tape is one finger front and back and run the test again mine went from 130 to300 without holding to 1390- 1500m holding it. If same for others think i know fix. I try on mine if works i post it.
                  Has anyone tried remote files to make sure they work
                    Tested 2 times same results here
                      Well I just tried the remote.conf for my A5 and I have a problem. I replaced the file and reboot than I powered down with the original remote and then tried to power back on with it and it would not work. So I tried my old X2 remote that was working before I changed file and it powered on. now i have to use old remote to power on then original remote works after it boots.
                        Which box do want tested or all of them?
                          You mean hold 2 fingers over the spot where the wifi "antenna/foil tape" is located and then test again without blocking that area?
                            I wonder if a copy is in the boot partition. I will look. Putting kiddo to sleep
                              One other would be good. I can't believe you have all of these
                                Can you go into setting and change what power does and see if anything is different
