http://freaktab.com/forum/tv-player-...-functionality
Mod for Tanix TX5 Pro MiniM8SII and Nexbox A95X COOLEME MB1 X9 Frankenstein Firmware WIP
My m12n s912 acemax IR remote working with this rom, power off and on working. But tx5 pro IR remote not working with m12n s912. Is there i need to edit to work with power on the box? I made change the remote.cfg but failed to manage to work with power on other button works even power off. Only power on not working.
Originally posted by Krisshin
Not all buttons are fully functional, but all major ones work fine.
Or better replace the config file as I have the same device as yours.
Originally posted by QuestE View PostHey everyone, and thank you prahjister for this awesome firmware but it seems I have a problem.
The wifi will connect and work however when I try to load any video or even to a speed test it will say something along the lines of "Network Communication Error" or "Trouble Communicating with the server"
This happens in Kodi, Youtube, Browser based speed test, and the Ookla speed test app.
If anyone would have any idea as to what is wrong it would be greatly appreciated! Thanks!
It was my fault for not being so quick to do things but I hadn't updated to the newest version (I'm slow with these things haha),
Now that I'm on the newer version all wifi issues have stopped. I also got this mod working on my T95X if you want to add that to the list of boxes it works on however I do not recommend the T95X
it has it's own host of problems and I find it infuriating.
Thanks to all who tried to help, problem solved!
Originally posted by ddogishere View PostYes
Also, if you are using a receiver then look at adjusting the offset on that too.
Originally posted by bluesmanuk
Then I would adjust the offset whilst playing a video and set it as the default for all videos.
How do you set it as default?
Also can someone give me there advancesettings/guisettings.xml-my kodi buffer when playing high bandwidth streams like 1080p/mpeg2 audio-my dl speed is very good so it could be the cache.
Thanks.
Thanks.
You can see it in this video.
The Enter key on my wireless USB keyboard does nothing. I saw on the standard ROM M8S Freaktab article where someone tweaked Generic.kl to fix this issue. Installing it on this ROM renders the keyboard inoperative. Anybody else have this same issue? I am using a null keyboard to eliminate the pop-up keyboard.Nvidia Shield (2017 & 2019), A95x Max, WD EX2 NAS
Originally posted by cjeman View PostThe Enter key on my wireless USB keyboard does nothing. I saw on the standard ROM M8S Freaktab article where someone tweaked Generic.kl to fix this issue. Installing it on this ROM renders the keyboard inoperative. Anybody else have this same issue? I am using a null keyboard to eliminate the pop-up keyboard.
8.27.16 Update
Finally looked into that stupid enter issue with keyboard users. To fix by hand change /system/usr/keylayout/Generic.kl 28 from DPAD_CENTER to ENTER. Or your can run update and it will do it for you. I can't believe I never looked into this before and how easy it was to fix.
So worth looking at the edit to ensure that it is correct.R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
There are currently 2084 users online. 0 members and 2084 guests.
