thanks
Mod for Tanix TX5 Pro MiniM8SII and Nexbox A95X COOLEME MB1 X9 Frankenstein Firmware WIP
Originally posted by prahjister View Post
thanks
Originally posted by dkholm56 View Post
prahjister, I hope I am asking this in the right forum and that I am not breaking any forum rules, but I have been trying to get an answer as to where I can get the latest build of your Frankenstein rom. I successfully flashed it to my Abox A1 Plus amlogic S905X 2g/8g box using the USB Burning Tool, but when I boot it up it gets to the AMLOGIC screen and freezes there. I think the build I downloaded was an early build. Can you please tell me where to get the latest build? I have searched for it but can't seem to find it. I do have the stock recovery for my box if something goes wrong.
thanks
The firmware is in post 1, along with information about updates that have been produced since it's introduction.
prahjister --> Kodi keeps crashing. I have asked you this before and you had mentioned that its a Kodi issue.
So I was wondering if I could install or update to a more recent version or build? I know Kodi 17 (Krypton) is still in beta so technically 16.1 (Jarvis) is still the latest version but this build is from August. So maybe they have released a new patch? or more recent build that we could put? I was not sure if I can just upgrade kodi due to lack of amcodec being present (maybe). Any suggestions on how we can upgrade Kodi?
OK I installed SPMC latest version (it installed as a separate app). However, the remote did not work for that app. So I had to uninstall it immediately. I also installed the frame fix apk. Not sure what it does but I just installed it. Haven't used Kodi so much to see if that had any affect. I will report back after some usage. The Kodi version I have is Kodi 16.1 build July 2016. That is all it says. So going back to my original question, can I install either Kodi 17 (beta) or a later build of Kodi 16.1?
Originally posted by prahjister View PostIf you are using passthrough then need to follow instructions for passthrough fix and give permission to the appon FTMC. I have installed the latest version of FTMC and when I check pass thru, there is no sound for AC3 or DTS. But AAC works fine. So clearly it is having issues with passing AC3 and DTS. I can get sound by checking 5.1 option, etc. so I am kinda OK but I really wish AC3 and DTS should have worked.
I have applied the passthru patch so not sure what am I doing wrong here. Do you know have any other suggestions?
There are currently 3793 users online. 0 members and 3793 guests.
