NEXTBOOK PREMIUM 7se ROOT?? (FOR 2013 MODELS??)
    I recently purchased a Nextbook Premium 7se, and the serial number is YFG0313---ETC
    I noticed that there are only rooting tutorials for older models. I haven't seen a new post about the subject since late 2012.
    Is anyone working on a root method for the newer models? (Mine was manufactured in MARCH 2013)
    If so, I would like to help because I really want to get this tablet rooted.
    THANK YOU!
    The Next7P12-8G?
    THANK YOU!
    If it is a Next7P12-8G or Next7P12-4G known as Next7P12-GP, then the only way to do it is the 3G dongle method http://www.freaktab.com/showthread.p...t-WORK!/page19 but if it is not then put the specs here so it can be identified.
      THANK YOU!
      Is this a Next7P-8G with Google Play?
      ShaunMT
      Freaktab Rom Developer
        Cydia Impactor works on the 2013 models manufactured before Black hat 2013(July, so serials before YFG0713) but not sure if anything after that will work, since google has patched the "Master Key bug #8219321"
          Next7P-8G Mod 3e Recovery, Stock ROM and Flashable Root
          Download Thread: http://www.freaktab.com/showthread.php?7011-Amlogic-Next7P12-8G-Modified-Recovery-Stock-Rom-amp-Flashable-Root
          Feedback Thread: http://www.freaktab.com/showthread.php?7012-Amlogic-Next7P12-8G-Modified-Recovery-Stock-Rom-amp-Flashable-Root&p=95740#post95740
          ShaunMT
            Actually I have a root method for BOTH models: http://www.freaktab.com/showthread.p...Noob-Friendly)
              Not working
              i followed your instructions very much carefully but it still says signature verification failed, while installing the package. And the installation gets aborted.
              Can anyone shed some light on it plz.......
                You need a modified recovery to flash anything on the current Amlogic based Nextbook models.
                Check your model and see if one is available for your model here in the forums.
                ShaunMT
                  Nextbook 7p12 with google play
                  ShaunMT
                  hi, thanx for reply.
                  Here are some things i have tried out and some specs of the tab.
                  Specs:
                  nextbook 7p12
                  s/n: YF 0513...
                  PHM727MC (i dunno what that means )
                  4.0.4
                  kernel 2.6.34* rooted with impetor.
                  *tried terminal emulator to bypass stock 3e recovery with some recovery found on xda.
                  *tried odin too.nothing seems to work
                  * and yes!!!!!! i have tried surely everyhthing found in this site and xda.things doesnt even goes with the tab.
                  plz help me out guys
                  ***CAN I ATLEAST HAVE CWM INSTALLED IN IT ???***
                  sorry for bothering..as i just got it to find out its useless and hopelessly slow on ics and i have no chance to get hands upon another tab for at least a year.
                  So you guys are kinda last resort for me.
                    ROOT FOR PREMIUM 7SE
                    THANK YOU!
                    Hello i dont know if anyone has found the easiest way i just got mine in the mail 10 mins ago rooted it by the time i turned it on. works perfect with supersu I used kingo root to do it with google nexus s adb driver installed i ran the kingo root and rebooted had everything working properly thought i would share this as a STABLE way to root the tablet
                      help pls
                      Hi i'm new to this rooting process. i've tried the instructions on this thread but it said installation aborted? what do i do? i have a nextp12 - 4gb
                      this is what it says:
                      E:failed to verify whole-file signature
                      E:signature verification failed
                      Installation aborted.
                        Cydia Impactor works on all current Nextbook models. The Cydia Impactor website has detailed instructions.
                        If you need an easier method, I plan to release CWM recovery and a flashable root package for this model very soon.
                        ShaunMT
                          ROOT NEXTBOOK
                          You can always use kingo root to if you like i could. Send you A link to the download thats what i've used and works fast and easy. He is right as well cydia impactor uses a master key exploit which is in a lot of devices still. They are both one click root methods I say kingo root because after done installing kingo root verifys root access which is nice. Knowing if your root installed properly.
                            ShaunMT
                            Thanks ShaunMT.
                            I'm currenlty downloading
                            Cydia Impactor from their site but there arent instructions. I'm using windows xp on my pc. Do i just unzip the file and execute any exe files in it?
                              Thanks ShaunMT.
                              I've never used it myself. The instructions are there on the Cydia Impactor website somewhere.
