NEXTBOOK PREMIUM 7se ROOT?? (FOR 2013 MODELS??)
when i try to find the uimage file it only shows on my pc when i plug my phone in to move the files over to my sd card then put sd card in my tablet and go thru recovery, but when recovery comes up it only shows the kyser_root.zip, ive added the folder i unzipped to the root of the sd card for the kyser_root as wellPantera
[Revolution is my name]
Originally posted by thedeadman21 View Postidk if this matters but since i cannot access any of the settings but the recovery on my nextbook i put the uimage and kyser on the root of my sd card, idk if there is away thru the recovery to add the programs to the internal storage of the tablet?Freaktab Rom Developer
Originally posted by thedeadman21 View Postdoes it matter that i put the zip and the unzipped file of the kyser_root on the root of the sd card?
It shouldn't matter that the both the zipped and unzipped version of the kyser_root.zip exist, however, just opening a .zip file is enough to break the file signature.
Download the kyser_root.zip again, don't open, just move the entire kyser_root.zip to the external sd card, turn off the tablet, hold volume- and power until it boots to recovery, then try installing the kyser_root.zip again.
If it still doesn't work, something is preventing you from booting in the modified recovery... unfortunately the stock recovery and the modified recovery look exactly the same. The only difference is that the stock one checks for Nextbook's private signature while the modified one checks for Google's public signature.
ShaunMTFreaktab Rom Developer
Originally posted by thedeadman21 View Posti rezipped the uimage to my root of sd, removed prior files from my pc and sd card, now waiting to move the entire zip of the kyser root file and wont open or touch it but will move it directly to the root direct of the sd card
the other .zip files can't be opened.
In your case, you'll probably want to install the ROM first then the kyser_root.
Originally posted by thedeadman21 View Posthell yeah it fixed this time, the stock rom actually booted this time, ty shaunmt, u rock
Verify everything works... some of these tablets have different hardware parts in them and require different drivers...
the only thing not working is the wi-fi, cant figure out how to fix it? everything else is working great but the tablet now will not pickup any wi-fi period, it a oct 23rd 2012 tablet, heard there were issues with wi-fi anyway to fix that?Last edited by thedeadman21; 23 March 2014, 05:11.Pantera
Originally posted by thedeadman21 View Postthe only thing not working is the wi-fi, cant figure out how to fix it? everything else is working great but the tablet now will not pickup any wi-fi period, it a oct 23rd 2012 tablet, heard there were issues with wi-fi anyway to fix that?Freaktab Rom Developer
no sorry it doesnt pickup any type of wi-fi, have even tried other apps to try and correct the wi-fi picking up, they do not work, this i believe happened when i used the modded stock firmware, im not in a huge hurry to fix it and anything u need of my tablet ill be more then happy to give.Pantera
Originally posted by thedeadman21 View Postno sorry it doesnt pickup any type of wi-fi, have even tried other apps to try and correct the wi-fi picking up, they do not work, this i believe happened when i used the modded stock firmware, im not in a huge hurry to fix it and anything u need of my tablet ill be more then happy to give.
If the wifi turns on, but just won't connect, then something else is wrong.
There are currently 1532 users online. 3 members and 1529 guests.
