NEXTBOOK PREMIUM 7se ROOT?? (FOR 2013 MODELS??)
Originally posted by dprssc View PostHi just tried to use cydia impactor and it doesn't detect my device. at first it gave me the option to install drivers for my device but after installation it keeps on saying "no device". what do i do?
It looks like the website changed recently... it used to have very detailed instructions about it's use.
I'd say either google search for an article with instructions for using it or contact the developer.
ShaunMTFreaktab Rom Developer
Originally posted by shaunmt View PostYou need a modified recovery to flash anything on the current Amlogic based Nextbook models.
Check your model and see if one is available for your model here in the forums.
NX007HD ,jelly-bean4.1.0 8G ,fingers r crossed,I used the root method given and worked flawless,excellently bulike a dumb by I tried to mod my dpi,"s from 160 to 165 and it said reboot now,screen booted got to the sunfowerloading screen and resides there now hoping zipping a recovery will bring it beck to life,great work bit he way guys,'shaunMT"and" finless'great work and a fan of all you,se do to help people.I hope I'm posting this right?Because it keeps saying needs two more words.
ShaunMT
Re: NEXTBOOK PREMIUM 7se ROOT?? (FOR 2013 MODELS??)
Originally posted by curiosity View Poststill say in message is to short,its like writing a novel.
Probably shouldn't mess with dpi... If you really want to mess with dpi learn how to use x posed framework... it has a module that lets you set dpi per each app and i think there is a way to disable it during boot if something goes wrong...
Sent from my SPH-L710 using TapatalkFreaktab Rom Developer
curiosity
Originally posted by shaunmt View PostThe easiest fix will be to boot the modified recovery and flash the stock rom.
.the method from the thread for the nxp12 ,I cleared cache media and had to install the mod recov. Before it would except the root pckge,,,the package had to stay zipped not unzipped,and its crazy but I had to repeat that a few times before it worked it didn't work the first shot,,,I have all the next books,that was the easiest to root with thread,,:-)
Sent from my NX007HD using Tapatalk
q
Originally posted by curiosity View Post.the method from the thread for the nxp12 ,I cleared cache media and had to install the mod recov. Before it would except the root pckge,,,the package had to stay zipped not unzipped,and its crazy but I had to repeat that a few times before it worked it didn't work the first shot,,,I have all the next books,that was the easiest to root with thread,,:-)
I'm probably late on the info but I can't use a PC all the time so I have to use other means like the package got me superuser,but won't give me root some apps say got root others say I don't my//uid isnt yifang the host is Iscao,I'm try in to change It somehow,
q
Originally posted by curiosity View PostI'm probably late on the info but I can't use a PC all the time so I have to use other means like the package got me superuser,but won't give me root some apps say got root others say I don't my//uid isnt yifang the host is Iscao,I'm try in to change It somehow,
and have u installed a super user app
Yup ,it put the su in the right spot it tells me its all cool just the uid isn't lineing up for some reason they put busy box in them preinstalled but they put the crapiest one in and you can't delete it until you get root the root check says its uid,I'm post almost there!!!!
q
Originally posted by curiosity View PostYup ,it put the su in the right spot it tells me its all cool just the uid isn't lineing up for some reason they put busy box in them preinstalled but they put the crapiest one in and you can't delete it until you get root the root check says its uid,I'm post almost there!!!!
There are currently 1947 users online. 0 members and 1947 guests.
