I HAVE NOT UPDATED YET so I have no input yet as to whether it works or not.
Biggest issue for me is Play Store does not work unless you Uninstall Updates and run it. After you run it once, it updates and you have to Uninstall the updates again to make it work.
Second issue is that Root Checker says it is rooted. I cannot however change any system files (rename, delete, etc..) even after installing busybox and supersu.
Maybe someone can get into these files and create a sure fire root method and we can get some custom ROM's.
I searched and found no references to these files so hopefully for my first post here, I'm not being a redundant dumb-ass.
Here are the links I received...
Files:
https://1drv.ms/f/s!Aj22POX1c5uCoSm0PbC8UZYu6kyj
https://1drv.ms/v/s!Aj22POX1c5uCoDovzxpIZsbCjqbF
