AMLogic (Sunvell?) T95x (Mini M8s ii clone) 1Gb/8Gb Stock Firmware and Recovery
Originally posted by KodiLoaded View PostI tossed together a custom firmware for the T95X, You can find it in my forum.
second thing any chance for adding support for bluetooth usb dongle ?
I am sorry I do not have a 2G/16G to work with at the moment, Currently this is a list of models I can do custom firmware for
Himedia Q10
KdLinks A300
Nexbox A95X 1G 8G S905
T95X S905X 1G 8G
I am willing to do firmware for any Amlogic models but it would require sending me a box to work with.
Originally posted by KodiLoaded View PostI am sorry I do not have a 2G/16G to work with at the moment, Currently this is a list of models I can do custom firmware for
Himedia Q10
KdLinks A300
T95X S905X 1G 8G
I am willing to do firmware for any Amlogic models but it would require sending me a box to work with.what about adding support for bluetooth usb dongle to firmware which don't have it is it even possible to do that ?
r -------------Download bootloader.PARTITION-----------
[19:28:01 331][HUB6-1][Err]--IOCTL_IDENTIFY_HOST_Handler ret=-116 error_msg=libusb0-dll:err [control_msg] sending control message failed, win error: The I/O operation has been aborted because of either a thread exit or an application request.
Originally posted by eweo911 View PostI purchased this item and it's having "issues" as reported by others. These files were sent to me as an update to possibly fix any issues the box has.
I HAVE NOT UPDATED YET so I have no input yet as to whether it works or not.
Biggest issue for me is Play Store does not work unless you Uninstall Updates and run it. After you run it once, it updates and you have to Uninstall the updates again to make it work.
Second issue is that Root Checker says it is rooted. I cannot however change any system files (rename, delete, etc..) even after installing busybox and supersu.
Maybe someone can get into these files and create a sure fire root method and we can get some custom ROM's.
I searched and found no references to these files so hopefully for my first post here, I'm not being a redundant dumb-ass.
Here are the links I received...
Files:
Code:https://1drv.ms/f/s!Aj22POX1c5uCoSm0PbC8UZYu6kyj
Code:https://1drv.ms/v/s!Aj22POX1c5uCoDovzxpIZsbCjqbF
Well, I still don't have an OTA in the form of a .img, so I have continued trying to use the USB Burning Tool. It now goes to 95% and says burning successful but on the bottom, it still shows as an error and the box will not turn on, light is still red/orange on the front of the box and the screen is still black. I am still not able to load into recovery and go through the SD card update. My PC and USB Burning Tool are still recognizing the box tho. I have read in other forums, with other boxes that there is either a jtag or jumper used to reset the box. Anyone know if that is possible to jtag this box? A jumper reset would be super easy tho, lol.
For the life of me, I cannot find a data sheet on the emmc flash chip (ncemasd9-08g) to jumper/reset it.
There are currently 1875 users online. 1 members and 1874 guests.
