Sunvell T95U - PRO Android 6.0 TV Box
    Originally posted by feelulive View Post
    does it have hdmi 2.0
    Yes
      Yes
      at gearbest....
      Question:
      Does it have HDMI 2 ?
      Reply:
      Hello Eric,
      It doesn't have HDMI 2.
      Thanks for your attention.
        at gearbest....
        Question:
        Reply:
        Hello Eric,
        It's wrong.
        All these boxes have HDMI 2.
        You can also check on a sales website here
          Thinking about getting this box or an egolggo s12 s912 tv box. This is my first post on this site so hello all. I have a t95z plus which is good wee box.
            Maybe the guy at gearbest thought he meant 2 hdmi ports. Can anyone suggest on what s912 to get apart from GT1 ?
              It's wrong.
              http://www.gearbest.com/tv-box-mini-...50.html?wid=21
              i checked
              upport 5G WiFi: Yes
              Bluetooth: Bluetooth4.0
              Power Supply: Charge Adapter
              Interface: AV,DC 5V,HDMI,Optical,RJ45,TF card,USB2.0
              Language: Multi-language
              HDMI Version: 1.0
              Other Functions: Others
              External Subtitle Supported: Yes
                is it power on/off button below the leds
                  In the comments asked it does have HDMI 2,
                  Should have one here in the next 24 hours or so.
                  All will be revealed....
                  Cheers
                    i checked
                    upport 5G WiFi: Yes
                    HDMI Version: 1.0
                    It's a typo.
                    It's the image that tells all.
                    In order to provide 4k@60fps, HDMI 2.0 is required.
                    None of the Android boxes of today come with anything but HDMI 2.0 and none would ever sell a single one if they didn't.
                    Only Intel boxes come with HDMI 1.4 (there is no 1.0 at least on anything that has been manufactured since 2004) Click image for larger version
                      Cheers
                      You already know the answer though lol
                        It's a typo.
                        Only Intel boxes come with HDMI 1.4 (there is no 1.0 at least on anything that has been manufactured since 2004) [ATTACH=CONFIG]n605795[/ATTACH]
                        thats nice, is it power on/off button below the leds, i care that button on boxes
                          It could be.
                          Very few come with a hardware on/off button these days but Trebor will know more when he receives his.
                          It might just be to adjust the clock.
                            Luv the look of this box... its to bad other manufactures cant seem to come up with a nice modern look like this... i Sell this box as my high end box over my typical M8S running linux & Kodi and find most of my existing customers are looking to upgrade to this box now that i have my linux /kodi software running the newest 17 beta 3 and 4 on it... People seem to really luv the look of the thing compared to all the standard black box types... Unit works much better running the current Kodi once you kick the Android mess... It came with 17.0 and Android 6 but seemed really buggy and locked up quite a bit... probably cause all of the junk Android 6 is running in the background cause once i removed Android and used linux with properly compiled Kodi ive not had any of the issues i was having while it was still on Android...
                            I just bought it off Ali awhile ago but am starting to look to source this in larger quantities now that i know it works well, but can understand peoples concerns over where to buy their toys these days...
                              Here we go with a bot of a look see at the Sunvell T95U, thanks Gearbest and DHL super fast as always to AU
                              S912 Cortex-A53 octa-core 2/16GB, Android 6.0 system, Bt4.0, 10/100/1000 Lan, Dual Band Wifi
                              All The Bits to make it happen, small compact unit looks good Click image for larger version
                              Front View with Power Off and ON Switch Click image for larger version
                              No Vents in the Base, Being Plastic easy fix if required Click image for larger version
                              Full view PCB Click image for larger version
                              WiFi Chip Click image for larger version
                              WiFi Antenna stick tape type attached to front inside face place and that LED, Click image for larger version
                              Reset Button Behind AV Port Click image for larger version
                              Samsung Ram and eMMC, Heatsink stuck on good so it can stay Click image for larger version
                              Out of the Box and fired up first impression pretty much a typical Sunvell Unit, Same UI/Launcher, little bit of Bloat installed, Kodi 16.1 and the usual addons,
                              I was concerned being an alloy Box how the WiFi would perform, but seems OK in my location.
                              Temperature a little warm idle in the low 50c. will see what happens when pushed.
                              Unit itself appears fairly snappy and set up easy in the first few minutes with Google and updating installing apps.
                              The Unit does have root bit no SU installed as yet.
                              The Only thing I don't like is the Big Bright Blue LED on the front next to the Clock, You can change the Colour with remote to green or a lighter Blue but it is Bringht, hopefully the next Rom update they will mode it so it can be turned off like other Sunvell LED displays,
                              The Clock is excellent not bright, fairly large display looks good, but the Led..
                                Nice looking unit.
                                Would have to slip a cover over that LED though, otherwise those on the ISS will be able to tell when you have it on.
                                "Power Off" switch ay, now that's a shame, would like to have seen "Power On" function too.
