Sunvell T95U - PRO Android 6.0 TV Box
    Yes a bit over the top,
    Also it is a power on switch,
    Pretty much a typical Sunvell box, as previous 912, just a different PCB and bits
      Couldnt see any air vent hole
        Yes a little ventless,
        The base is plastic so you can go silly with a drill if you like and make some.
          i think board is over the base so box would be killed
            T95u Pro Amlogic 912, 2/16GB
            A few benchmarks etc for the purpose of comparison to others found of Freaktab,
            Think they will all be fairly close.
ID:	606072 Click image for larger version
ID:	606069 Click image for larger version
ID:	606070 Click image for larger version
            Full Detail > http://browser.geekbench.com/v4/cpu/861831
            Full Details > http://browser.geekbench.com/v4/compute/180743
ID:	606071 Click image for larger version
ID:	606076 Click image for larger version
              Yes you are correct,
              It would be advised and I think obvious to remove before drilling,
              If you're handy with a small screwdriver to disassemble the unit,
              if not ask a professional to assist.
                i ordered one, this will be my 2. s912 box,
                i think sunvell has thought no needed for vent holes or did they really forget it ,
                if it gets so hot i would upload a how to drill Sunvell T95U Pro video on youtube
                and now i wonder how did u open the box without breaking the parts, not zoomed pics or a video would be nice
                  Screws on the under side x4 remove, then slide/push the alloy cover to the front,
                  Of late this is a very easy unit to remove cover.
                    ah ok i was thinking back or front panel was attached to red cover
                      I have one as a test unit from the China Manufacturer....Nice unit with only 2 major drawbacks....the no rubber feet...major issue for furniture... and the ultra bright led in front that completely blocks out the ability to view the clock. If you went inside the unit and clipped that led out completely you'd be doing yourself a favor and then be able to see the clock. Performance wise it's nice little unit though. I do prefer the ones in the black cases over the red...but that's a personal thing.
                        my box arrived today it looks like a huge oven on photos but in hand its small and cute, but not tried yet, maybe tomorrow i can
                          Yes I put a bit of Black Tape to cover the LED inside window easy.....
                          Piano Black would have been excellent but a good little mover for sure.
                            It looks smart tbh, need a new box this looks a decent upgrade from m8s - is this rooted box ? What's the remote like ?
                            Sent from my MI PAD using Tapatalk
                              I have no problem with remote, dont try and do a moon bounce is all i can suggest.
                              I think it had root(if not easy to do ) let you know when it's not in use the official wife tester is netflixing...and you think I can have a look.
                                Cheers Trebor :-)
                                there cheap enough at under £50
