Sunvell T95U - PRO Android 6.0 TV Box
Originally posted by Yemble View Post
Definitely try a different cable, as the one supplied is not exactly "professional grade".
http://www.phonearena.com/news/How-t...-issue_id63536
Actually its not oversharpening, its a rate of blurring (edges).
At the bottom of the page there is forum link, but scripts in the zip it is a little chinese for me...
If somebody (e.g: superceleron) is excel at deep image modification, could check what is the actual settings in the rom.
Originally posted by fantonima View PostSomeone succeded in installing and upgrading supersu on last original rom(V05)?
With superceleron, power led in my one's change color from green to blue continuously....so i come back to last v05...there is a way to stopping the led colour change in sc rom?
I am not aware of any ROM, other than SC, which has a properly implemented root for the T95U.
Originally posted by Ricey155 View PostThink I might need to upgrade, I just received a Rii Mini I24 with a X96 box but the dongle was missing so can't try it to see if it's any better :-( guess the air mouse is better would a bluetooth option be even better ?
Before you upgrade, would you please do me a favour and upload a copy of your /system/media/bootanimation.zip file (to Mega if convenient), which I presume is still branded T95U on your box. When you upgrade to SC, this file gets replaced with a FreakTab branded animation which is far inferior than the Sunvell original, IMHO. Also, if the ZIP does not include the audio track, would you please upload that as well. It should be in one of the /system/media/ sub-folders and possibly named PowerOn.mp3, or similar. This file also gets wiped by SC.
Ricey
Put "bootvideo" in /etc (if there is one there already back it up if you want)
Change permissions to 644
No need to delete /system/media/bootanimation.zip or PowerOn.mp3
Originally posted by lvlacleod View Post
Extract "bootvideo" (it has no file extension)
I can decompile from stock firmware but the only firmware I have only has the animation zip but no sound. Have you actually tried what I uploaded because as far as I can make out it is the original animation with the sound embedded which seems to take precedence over any bootanimation.zip in /system/media.
If I could find the original firmware that came with my box then I could get the original bootanimation.zip and PowerOn.mp3 but I can't find it anywhere. The only one I have is V5 which Sunvell seem to have got rid of the boot sound.
There are currently 4917 users online. 1 members and 4916 guests.
