Sunvell T95U - PRO Android 6.0 TV Box
On a slightly different topic, I am trying to hook as many of the installed apps into PlayStore as possible, so that they are regularly updated. I am struggling with SU though. Although I have the GUI front end installed, it cannot update the binary file via the "Normal" method. As I don't have TWRP or CWM installed, what would be the safest method for getting the SU binary updated?
Why do we have to put up with persistent bloatware on this TV box? I mean that you uninstall stuff, like Sky Live, MobDro, Show Box, etc., etc. and it just reappears after the next reboot. How sh!t is that?
I've been looking for a free solution for this nonsense and eventually came upon App Freeze. Yes it is a bit crude and unpolished, but it does stop this junk from running and yes, it is persistent across reboots.
Note that freezing apps is not the same as uninstalling them. If you uninstall one of the apps that you have previously frozen, then it will magically re-incarnate itself like a pheonix from the ashes and you will need to re-freeze it to get rid !Last edited by Yemble; 09 December 2016, 16:19.
Did you update the firmware what the mod posted seem to work fine for me just install from SD card. Then just remove them in the settings apps uninstall each one by one. Then Installed SuperSU Nova Launcher and GMD Auto Hide Soft Keys, Then change settings for nova and auto hide soft keys to how to like them.
i just received the tvbox and i have this issue....after running kodi 16.1 and watching something when finished and switch to another chanel or movie i get a message kodi had to close due to unexpected issue and i restart kodi....
what do you think??? should i go to kodi 17.0 ???
thanks in advance
You don't need to updated kodi Just get Ares wizard install Pulse CCM. Do a fresh start to remove all the other build. Then reboot kodi. load Ares wizard again then install no need to reboot box just Close kodi from recent items. https://www.youtube.com/watch?v=XbJwR4_kOPY check this video it will help.
There are currently 1423 users online. 0 members and 1423 guests.
