X92 TV Box S912, Android 6, 3/16GB, Dual WiFi, Gig Lan
    Originally posted by wj2es View Post
    It's ok for 2/16 gb.
    I downloaded and flashed it and everything is good. The best firmware until now!!!!
      I have a x96 box and when I plug it up the red light flashes and goes off can anyone tell me what's going on?
        Hi. Please tell me, what is the OTA Version # of this firmware.
        Thank You
          Hi here is the link you can check the firmware update. You have to choose from X96.
            S905x Android 6.0 arm cortexA53 4k 60fps vp9hdr10 h.265 10 bit model x96 MAC:C44EAC092809
              1.06 30.10/2016
              S905x Android 6.0 bras cor
              s912 =x92 box tv
              http://freaktab.com/forum/tv-player-...v-players/s912
              ici pas s905x
              ici
              http://freaktab.com/forum/tv-player-...-players/s905x
                x92 yes ok 2g/16g nonl a not x96
                1.06
                To have the bars installed
                XposedInstaller_3.1.1 (google search)
                And GravityBox_Marshmallow_6.2.1 (google)
                30.10.2016
                  1.06
                  30.10.2016
                  Thank you my friend, I installed the XposedInstaller_3.1.1 and GravityBox_Marshmallow_6.2.1, I run the gravity box but I have'nt got the bars.
                        Originally posted by edwardsfrequent View Post
                        Which image file are you planning to use? The one karaganda72 shared? Let me know how it goes. I'm still waiting for the cable.
                        Thank you
                        Sorry for the slow response, I've been quite busy.
                        Pleased to hear that your X92 is up and running again.
                        I have also just got mine (3/16GB) working gain using the IMG file that karaganda72 put a link to in post 54. Thank you karaganda72.
                        Thank you also edwardsfrequent for your additional information which helped. Just a bit more info I can add.
                        The recovery button through the AV port on the back does NOT need to be held in to complete this procedure.
                        The USB cable and X92 power can be plugged in before shorting the pins on the Samsung IC. I'll attach a photo to confirm the pins to be shorted.
                        The Amlogic software I used to flash the firmware was v2.0.7.2 from here:
                        I just ran the Amlogic software on my PC, then connected the USB/USB cable between PC and X92 (top right USB) and connected the X92 power supply.
                        Next I just shorted the pins and the PC then requested to load firmware for the X92 USB device. The PC then searched and loaded the USB firmware.
                        Once the PC is connected the short does not need to be left on once the PC has connected.
                        The first two attempts at loading the firmware it failed at 4%. It worked correctly on the third attempt.
                        The firmware that karaganda72 provided is actually earlier than what was on the box before it was bricked.
                        Before it was bricked: 20161008.17:46
                        After karaganda72 firmware: 20160924.11:51
                        Also, before it was bricked I did not have the OTA update app. I do now.
                        Is there any later good firmware for the 3/16GB X92?
                        Is the firmware definitely different for the 2GB and 3GB models?
                          Originally posted by karaganda72 View Post
                          Thank you karaganda72 and totor54 for your help.
                          I installed the systemUI the SystemUI.t95z the XposedInstaller_3.1.1 (there is not in google play, I found it in XDA forum) and GravityBox_Marshmallow_6.2.1 and now I have the bars.
                          Thank you again
                            All hot forG947 .. and karaganda72
                              Hi we support X92 TV Box 3GB 16GB small quantity wholesale and please check https://goo.gl/ISHLFp if it can hep you.It is free shipping!!!
                                for G947
                                Decompiler and recompile a .img ROM
                                CustomizationTool
                                Decompiler and recompile a .zip update ROM
                                System_Extractor-WIN-master
                                File to decompress and use
                                sytem.new.dat
                                system.patch.dat
                                system.transfer.list
                                for the
                                .apk
                                systemui.apk
                                AndroidMultitool_3.5.9
                                Do not forget to put the framework-res.apk in the file Framework-Files
                                For the rest you
                                Notepad ++
                                build.prop
                                .conf and the rest
                                Very important
                                The files it is 755
                                The files (.apk .prob bluid) c'and 644
