X92 TV Box S912, Android 6, 3/16GB, Dual WiFi, Gig Lan
Hello
first thank you for your help.
1 =I have flash the " TOSHIBA " puce than a " SAMSUNG " puce and i had a connection usb to my computer ( must stay few minutes in court circuit )
2 = i have use usb burning tool to flash aml_upgrade_package1 ( post #54 )
after it my x92 reboot i have the image on my tv of the boot ( happy ) and the box finish installing android.
I have made some test all is ok wifi / ethernet / play mkV / usb / sdcard ....
So now i have a question. I'm in version :
model number : X92
android version : 6.01
Build number : 20160924.11:51
Ota version : 1.04
when i cheak for an upgrade onlive the box say i can download " update.zip "
I have download it , i have lunch installing but the box reboot , open recovery mode and .... ERROR ....
Can you help to have the last ota version ? I affraid to brick AGAIN my box
I would like no loose all again
thank you
model number : X92
Ota version : 1.04
thank you
Originally posted by karaganda72 View Post
Install this firmware via stock recovery.Download to sd card,then boot into recovery and from there select update.Via firmware update arrives for the firmware version 2Gb/16Gb,then get a brick : http://www.mediafire.com/file/7g8zev...2_3GB16_SD.rar
Hello , thank you for help,
ok for the methad .
in the mediafirer link the update is 763.48 Mb and on the cloud ( post #125 ) it do 390 MB ( for the version V5_X92_3GB_ROOT_011116_MOD.zip ....
what is the difference behind this 2 update ? what is the best ?
on the cloud just take last version or need flash all ?
thank you sory for my noob
Originally posted by zap89 View PostHello , thank you for help,
ok for the methad .
Hello, it's again me ^^
but now i have a good news . It's OK i have installed V5_X92_3GB_ROOT_011116_MOD and all is OK.
First time i hade* a error to install update. I had must format my USB card in FAT32 ( it was in NTFS ) and i the update was OK. IN NTFS impossible install zip file for update.
This mod is the best for me ( navigation bar and notification bar is great ) . In this time i am testing all ( games movies transfert usb/nas ) for cheak if all is ok.
I back to you after my test.
THANK YOU very much for your precious help
Happy new year everyone!!!
Base version on 01112016
This is my V6 mod for 2GB\16GB version only - https://cloud.mail.ru/public/BSZK/vXbdv782A
And this V6 mod for 3GB\16GB \32GB version only - https://cloud.mail.ru/public/GmhU/ioJ3srN8H
Flashing from SD card on stock recovery or app in system Backup&Restore.
Changelist:
First start language - Russian,sorry )
1. Firmware clear&stable (All perfect working,no error)
2. In V6 replaced Kodi on SPMC 16.6.0 for Amlogic (Stable)
3. Mod tvlauncher (bugfix)
4. Icon replace in framework.apk
5. Fix russian translation,for russian community
5. And more....))) I do not remember
There are currently 1827 users online. 1 members and 1826 guests.
