X92 TV Box S912, Android 6, 3/16GB, Dual WiFi, Gig Lan
Originally posted by taliesin View PostHi Samde, installed your Firmware (the port one) the issue with the green screen is still present (changed 3 hdmi cables and all ports on my tv) it shows a little less often that with stock firmware. Just a little question regarding the port firmware you pointed me to, It seems unable to connect to a 5ghz network is my mistake or is a property of the firmware so to speak? (no big issue my normal wifi is fast enough for my needs)
Thanks again for any help or advice you can give.
Hello to all from when and broke the hdmi card onkio amp or attacked the TV box with HDMI cable into the TV philips or problems with green screens I tried six firmware found on the net without being able to eliminate the problem, now let me try to put one SPLITTER HDMI from box tv and philip.
The TV box when it was attacked on onkio amp did not have these problems or tried other tv box that my friends have lent me beelink gt1, yundoo y1, x92 green screens
V9 NEW version available1. Clear and stable,this firmware build in new soft,have new sertificate signature
Changelog:
2. Fixed mouse cursor disappearing
3. Fixed crash "system interface"
4. Updated (Root Explorer,WebViewGoogle,Play Market)
5. Add new app
6. Replace icon LauncherTV (Paper icon Android 6)
7. Only have 3 buttons in nav.bar (Back, Home, Recent) .SystemUI stock and stable. Status bar have 2 button (wi-fi,bt)+brigtness( del in next firmware version)
8. SPMC deleted in firmware replaced by Perfect Player
9. First boot logo replaced
10. Bootanimation replaced (Progress bar loading with %)
Download:
FOR 2GB
FOR 3GB
Originally posted by SAMDE View PostV9 NEW version available1. Clear and stable,this firmware build in new soft,have new sertificate signature
Changelog:
5. Add new app
Download:
FOR 2GB
FOR 3GB
Changelog:
5. Add new app
Download:
FOR 2GB
FOR 3GB
Thank you very much for the new update, however how to hide the navigation bar ? it was there on your previous build. when i watch on full screen the movie runs in window mode because of this navigation bar it would be great full if you include an option to hide the navigation bar as before. thank you.
@SAMDE and others who own this box.
b4 buying this, would like to know how this box performs:
1. does this plays all thos 4k 60fps hevc videos ?
2. vp9 4k 60fps ?
3. i read that the IR remote does not wkr correctly? is it so bad ?
4. While playing games, does the box heats up ?
5. does youtube stream wrks ? wats the max resolution people have checked ? 4k, vp9 too ?, any issues with wifi ?
6. any issues in attaching high capacity HDDs ? like 2TB, 4TB ?
7. can you power the box from the IR remote ?
2. vp9 4k 60fps ?
3, the IR remote is not so bad, you have to point it toward the unit though.
6, I have 4 HHD attached, each one 3tb (one through an usb hub to have also wireless mouse and keyboard) all works perfectly
7, yes turn on and turn off from the remote.
I leave other questions to others that might have tested the box more than me
regards, Taliesin.
Changelog:
5. Add new app
Download:
FOR 2GB
FOR 3GB
thanks as always for your work
Regards, Taliesin
With samde fw the box is stable and so far it has not crashed even once.
as I told I almost never tried stock firmware.
regards
Taliesin
SAMDE or everyone else that can help me
Sorry for being a bother, I decided to buy a composite splitter to avoid the solarized screen issue entirely. I wanted to move onto your new firmare v8 or v9.
I just wanted to know if in those fw the wifi 5ghz is active since in the port one you pointed me to last time it was not working and if in version 9 (or higher should you release them) perfect player can be uninstalled or kodi / spmc can be installed together.
Thanks again for your answers
regards TaliesinLast edited by taliesin; 08 February 2017, 17:47.
There are currently 2917 users online. 1 members and 2916 guests.
