https://forum.xda-developers.com/att...0&d=1404376236
X92 TV Box S912, Android 6, 3/16GB, Dual WiFi, Gig Lan
Originally posted by pavlik View PostYou can test my mod from Ugoos port - its for X92 3GB model ONLY!
- a lot of unuseful (for me) system apps removed (included ugly bootvideo),
- Nova Launcher (only),
- Greenify (hibernate apks),
- root + SuperSU
- SD Maid (cleaner),
- Titanium Backup (backup apks),
- Xtreme Booster (RAM optimiser),
- ES (file explorer),
- working YouTube (credits for SADME),
- hacked java - possible to install older version of apks,
- Xposed Framework + RootCloak (hide root) + AdBlocker Reborn (anti ad) + XInternalSD (data/obb on extrenal storage).
- NullKeyboard (attention: no screen keyboard in this mod! / some crashes in Options/Language but You do it only once).
Plug any USB keyboard and mouse or use RemoteIME on Smartphone and download any from PlayStore if You need.
- busybox, init.d, bla bla bla.... I dont remember... Oh Yeah, fixed Enter in real keyboard.
After first launch config Greenify from Xposed because it has probs with asking for root rights. Its not the mod problem but apks itself.
You also get some errors (Xposed at system launch, YT at it first launch). Dont bother.
Without any configs (Greenify, settings) the rom can be little slow at beginning (especially power menu).
How to install:
- install Rashr from PlayStore and flash TWRP recovery if You dont have already ( http://www96.zippyshare.com/v/xyy70iZb/file.html ),
- unpack files to SDCard or flash drive with TWRP structure eg: TWRP/BACKUPS/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/X92_2017_04_17/files
where xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx is serial of Your box. You can easly check serial in SPMC/Kodi in Settings/Architecture.
- boot to TWRP and wipe/advanced wipe: davlik/ART. system, data, cache,
- go to restore, choose staorage and click backup folder,
- on the end reboot and thats all.
Unpack 1st part with 7-Zip.
Code:1 - http://www71.zippyshare.com/v/IbZWQWkS/file.html 2 - http://www85.zippyshare.com/v/rqERCsv5/file.html 3 - http://www118.zippyshare.com/v/TkbPHCIp/file.html
In order to use your mod I must install ugoos firmware before? Or can I istall your mod directly from the system my box came with?
Can you explain to me how this works?:
"- unpack files to SDCard or flash drive with TWRP structure eg: TWRP/BACKUPS/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/X92_2017_04_17/files
where xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx is serial of Your box. You can easly check serial in SPMC/Kodi in Settings/Architecture."
Do I have to creat a folder in the flash drive like this: TWRP/BACKUPS/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/X92_2017_04_17/files?
Thank you!
Only hacked YouTube or YouTube TV will play content. You cant also use Chrome - Youll get only bufor animation.
YT TV: http://www90.zippyshare.com/v/ci1Ooey2/file.html
https://productforums.google.com/forum/#!topic/youtube/3FZ1LDSOFqk;context-place=topicsearchin/youtube/category$3Aask-a-how-to-question
Hi all, i have problems with my x92 Android tv box (ram 2 gb),i'm looking for the Vendor_0001_Product_0001.kl original file or the keylayout full folder, (location: system/usr/keylayout)
i've replaced the original file with another one and now my remote doesn't work well ,i've tried factory reset but doesn't work...please help me thanks!
Hey guys.
I'm trying to get audio out of this Android TV box by hooking up some headphones to it.
I tried plugging in headphones in the AV port but nothing happens.
I've set the "digital audio" selection to PCM (other options are HDMI and SPDIF, neither of these work either from the AV port.)
Audio over HDMI and optical audio work perfectly.
The only thing I can think of is that the AV port has some strange pin out that doesn't pass audio over the headphone jack. But then again, I don't get audio on the right side nor left side.
Perhaps it's the other 2 parts of the minijack?
If someone can test this for please, I would be grateful.
I did flash my unit with the Ugoos firmware for the same device. But I really doubt that that is the issue.Last edited by gabb; 26 August 2017, 01:51.
There are currently 3522 users online. 0 members and 3522 guests.
