X92 TV Box S912, Android 6, 3/16GB, Dual WiFi, Gig Lan
I use sometimes Terrarium TV and play it through SPMC.. With 6.0.1 and the Auto Frame Rate Fix apk everything plays great at the correct frame rate when I check the TV's info. I couldn't get it to do that with 7.1.2. Perhaps the version you have used has been fixed? Have you checked on the TV that things that should be displayed at 24Hz, 50Hz & 60Hz are doing so via the TV's info? 24Hz played at 60Hz doesn't look too bad yet far from ideal, but 50Hz played at 60Hz is horrible. The only good thing about the display is that you know it's powered up. Sometimes mine doesn't turn on first time as the IR receiver on the X92 is not great - even with a much better universal remote.
Originally posted by toczny25 View Postx92 3gb Amlogic s912
During the update was stopped,
Now you can not connect to PC - USB Burning Tool
Drivers installed.
The BOX logo X92 lights up
Display does not work does not burn
Reset does not work
x92 3GB Amlogic s912
after the upgrade, he is dead.
the display does not light up
reset can not be
corpse
What can you do with it?
Good Day Everyone,
I purchased my x92 3g/32g and it runs great when playing games and anything else. After a day or less though, it will just freeze and any audio playing will repeat in an annoying glitch fashion. It happens in most apps or even when the TV box is idle on the home screen. I found that doing a factory reset of the box alleviates the issue for a few days but it quickly returns after using the box for a couple days. My Android version is 6.01, build number: 20161026, and ota version 1.0.5. Could this be due to me running an older firmware version?
Hi Everyone,
Finally fix my issue with the broken wifi.. by purchasing a mini router with AP mode.
another issue came up now.. my box 3/16g can not play youtube.. after i upgrade the youtube app.. it seems can only play with an elder version?
according to the link below,
https://productforums.google.com/forum/#!topic/youtube/3FZ1LDSOFqk;context-place=topicsearchin/youtube/category$3Ayoutube-android-app
it seems quite a few people having the problem.
Is anyone here manage to fix the issue?..
Kind regards,
William
Kind regards,
William
Â
Originally posted by mctiew View Post
If youtube for android tv works, why bother with youtube for phones ?
Â*
I meant the 2015 version youtube for x92 is worked, but not any updated one.. I am afraid google will stop supporting old version youtube anymore, then my x92 will be just like a piece of brick then.. since i only use it for watching youtube..
There is a YouTube for android Tv, which is the latest and current version. Nothing to worry.
I meant the x92 i got, it has a 2015 version youtube which is working. but once i update the youtube app, it will stop working anymore. you can open up youtube app, but you can not play the video..
which has been discussed in the below link,
you have not got what i meant..
Other alternatives work better.
Originally posted by SteveC View PostI use sometimes Terrarium TV and play it through SPMC.. With 6.0.1 and the Auto Frame Rate Fix apk everything plays great at the correct frame rate when I check the TV's info. I couldn't get it to do that with 7.1.2. Perhaps the version you have used has been fixed? Have you checked on the TV that things that should be displayed at 24Hz, 50Hz & 60Hz are doing so via the TV's info? 24Hz played at 60Hz doesn't look too bad yet far from ideal, but 50Hz played at 60Hz is horrible. The only good thing about the display is that you know it's powered up. Sometimes mine doesn't turn on first time as the IR receiver on the X92 is not great - even with a much better universal remote.
I am saying it is not important to know that.
I thought the one i have got and the one i updated to were the android tv version. what you mean is i got a version for mobile or something else? could you please provide me a link for ther android tv version youtube or ay other alternative you mentioned?
There are currently 2354 users online. 1 members and 2353 guests.
