X92 TV Box S912, Android 6, 3/16GB, Dual WiFi, Gig Lan
Originally posted by stasio View Post
Originally posted by MekkelRichards View Post
Can I flash the TWRP file on my x92 that is mentioned in that thread? I ask because that thread is for the a95x box, rather than our x92.
There is however no particular need to install TWRP into the internal flash. If it boots, the TWRP functions correctly, it already serves the purpose. Whether it is on SDCard or internal flash, a matter convenience.
Originally posted by mxqpro View Post
The instruction to install is applicable for all amlogic devices. Our box has a reset button on the AV port.
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Simple swipe.....you got mouse connected...?
In the process of installing the latest ROM as posted on MEGA on pg26 (x92 3g 171211.rar), I got an error message: "This package is for "q201" devices; this is a "q201_64".
Error message is attached as a picture as well.You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Sorry, I bought a separate mouse for the x92, but am still waiting for it to come in the mail. I did just connect a USB mouse though and was able to get into TWRP. I successfully flashed the TWRP that you posted.
There is a mismatch in TWRP and the ROM. Many ways to get it out, perhaps easiest is to edit or delete first line of the META-INF/com/google/android/updater-script. You would have to unzip the ROM, modify and zip it back.
Are we sure that this ROM is meant for the X92 3GB?
Perhaps another way to do it is :- Inside the archive file, there is a stock recovery.img. You can use TWRP to install back the original recovery ( and wipe out TWRP ).
By using the stock recovery, then perhaps it will be compatible with the updater.
You can unzip it and look at it yourself.
Originally posted by d99 View PostHey everyone, I'm trying to reflash my box here. I downloaded the files from this site and I'm following the instructions here - https://www.entertainmentbox.com/how...-burning-tool/
At the step to upload the iso, is it the recovery.img file we're uploading and using?
Anyone know?
Someone ask me about TWRP installation in private. So I reply here :
The TWRP requires no installation. Just copy the image.img to SDcard, rename it as recovery.img. you can do it on a PC.
Then on x92, shutdown and remove power. Insert SDcard to x92. Use a toothpick press and hold the button behind the av port and then insert back the power. After a few seconds, if you got the correct TWRP, it will boot.
If it doesn't, try another time or try another TWRP image.
Â
There are currently 6386 users online. 0 members and 6386 guests.
