Ugoos firmware need to be ported for it to work on x92.
X92 TV Box S912, Android 6, 3/16GB, Dual WiFi, Gig Lan
Originally posted by mxqpro View Post
I think you misunderstood. He dropped Android 6 Ugoos and went to stock 7.1.2 via stock Android 6.
So, I read most of the thread and 4PDA and did not see talk about 7.1.2 port from Ugoos, so I guess we dont know if one is out there?
Probably something meaningless, could be inherited from some older firmware. My guess.
By the way all the boxes I checked so far have the same line there.
Sounds strange to me at least.
Another question, I want to use a Minix A2 lite air mouse on this box., but obviously the power button on the remote doesn't work.
Any idea how to fix that.
Is there a remote config file somewhere in the clouds that I could use for this?
No need for the stock remote to work, as now it is only used to power up the box.
Originally posted by Jancales View Post
Doubt it's from older firmware since the date is correct 11/12/2017 and the box never had a S905X processor lol.
Originally posted by Jancales View PostAnother question, I want to use a Minix A2 lite air mouse on this box., but obviously the power button on the remote doesn't work.
Not saying firmware is old. Developer never build things from scratch, once something gets into a text file, if it is not broken, nobody will bother to remove it.
So I flashed again the stock 6.0, then applied the 7.1.2 December 11 OTA.
Changed the build properties to force landscape, and that fixed the issues with the apps that didn't work on the stock rom.
This firmware also runs about same temperature as the Ugoos, so happy for now :-)
Originally posted by sabre66 View Post
Hi Jancales, so I have tried everything. Looking to get back to square one. I have the Ugoos 1.1.4 right now, and would like to go back to stock as you did. Could you please tell me 1-what method/firmware you used to get back to A6 stock, and then was the 7.1.2 update using SD card / update.zip? I am sorry to ask, but I have tried most everything. Thanks
You can then download the December 7.1.2 OTA, which is linked a few pages back in this thread.
Open the zip file and extract the zip only to an sdcard, do not copy the other 2 files.
Boot up in recovery by holding reset button, install update from ext / sd card.
You will see the green android man and update will fail.
Press reboot and it will automatically boot up in recovery. ( no need to keep reset pressed)
Select install update from ext/sd card again.
Now you will see a different symbol ( white circle) that the update is going on, and it will complete.
Just to confirm, is that the SD card "Firmware from 05022017 "
or the PC "Firmware from 2017.05.08 OR re-casted on 08/05/2017 "?
EDIT -- ok, got it. Thanks so much. And you did some edit to build properties -- does that help a lot?
Originally posted by mxqpro View PostSomebody posted a ported minix firmware for x92 on the 4pda x92 thread :-
https://drive.google.com/file/d/1QtA...kqgX54yMC/view
It's an Android 6 firmware.Last edited by stasio; 25 February 2018, 21:24.
There are currently 1513 users online. 3 members and 1510 guests.
