X92 TV Box S912, Android 6, 3/16GB, Dual WiFi, Gig Lan
    Originally posted by sabre66 View Post
    Just to confirm, is that the SD card "Firmware from 05022017 "
    or the PC "Firmware from 2017.05.08 OR re-casted on 08/05/2017 "?
    EDIT -- ok, got it. Thanks so much. And you did some edit to build properties -- does that help a lot?
    Just discovered that from the Ugoos port you can apply the stock 20170916 OTA and from that one you can apply the stock 171211 OTA 7.1.2, so no need to flash the May stock firmware first.
    Yes I edited the build properties where I change the persist app to force_land, and that helped a lot.
    Several live tv apps that wouldn't open, or would show a limited channel list worked perfectly after changing the build properties
    Edit : After the the 20170916 OTA you need to do a factory reset
      Found on xda forum Amlogic Flash Tool & Recovery Porter.....
      and Poison Rom 2.0 for S912.
      Edit:
      will be interesting to try this Poison Rom.......
        Edit:
        Most like has more or less same issues as the Minix port.
          I dont think so.....reading complete threat, is for almost every s912 device, very fast and not much complains.
            99% sure the display will not work, and it will depend on your wifi chip if that and bluetooth work. The latter can probably flashed externally, but the lcd display not
              So far nobody complain about this on many different devices with display...
                What you're waiting for to flash it on a X92 and report back?
                By the way, I received the image of the stock 20171211 firmware.
                How do I load it up to Mega?
                  Thank you. Got it going on 7.1.2 with your help.
                  Now thinking about this Poison ROM...
                    If I am not outstation, for sure will try......next week coming back.
                    Open account on Mega...it's free,you can upload up to 50GB.
                      Ported UGOOS AM3 1.1.6 for X92_3GB
                      Not working: bluetooth, wifi, display
                      Any chance to get this image ?
                        stasio
                        Any chance to get this image ?[/QUOTE]
                        Sure, my upload speed here in Thailand is horrible, so if someone could upload it to Mega.
                        https://wetransfer.com/downloads/137...7104817/1a84ce
                        The link will expire on 6 March, but download speed is good.
                        The Ugoos ports I downloaded from 4PDA all had working wifi, bluetooth and display
                        I wonder why when you paste a link in a post the software completely messes up the quoted post
                          You need download the right type of ROM, from 4pda.ru x92 website.
                          For usb burning tool, you use firmware -> 'for firmware from PC', according to google translate. Unzip or unrar until you see something.img.
                          Thanks a lot bud, It worked perfectly, you just saved me two boxes
                          I wish there was a way to revert that 24H display to 12H. On the old and new firmware, no matter what you set it to, the display always shows it in 24H format.
                            Which firmware and which display ?
                            If you are referring to Rikomagic mk22 ROM and the LCD front display, the time display can be changed by editing /system/etc/vfdd.ini using ES File Explorer.
                              X92 firmware from here -https://4pda.ru/forum/index.php?showtopic=773971&st=8400#entry63426096
                              Is there a file where I can edit the clock to display in 12H format?
                                I think there is no easy way to change it for this ROM. May need to go to the extent of replacing the boot image.
