X92 TV Box S912, Android 6, 3/16GB, Dual WiFi, Gig Lan
    Originally posted by Jancales View Post
    The Ugoos ports I downloaded from 4PDA all had working wifi, bluetooth and display
    Ported UGOOS AM3 1.1.6 for X92_3GB
    btw,
    Image of the stock 20171211 Android 7 firmware
    Originally posted by d99 View Post
    I wish there was a way to revert that 24H display to 12H. On the old and new firmware, no matter what you set it to, the display always shows it in 24H format.
    Go to Setting...=> date and time....=> "Off" 24 hours format....
      Anyone interested in trying ROM can try this one :-
      https://mega.nz/#!bYEylAwS!p9LQy-C5P...RrRpGqf-lNraPI
      This is a modded one based on x92 Rikomagic MK22 ROM. This is for 3G only.
      1. The LCD panel works with displaying time, temperature, and flash activities.
      2. The modified TROM launcher is reverted back to the Lighthome launcher. The TROM launcher has Russion mod embedded inside while the Lighthome is English. Also modified a few non-working panels in the launcher.
      3. Supersu.apk and su are removed. Totally replaced with systemless Magisk.
      4. Original automatic framerate adjustment is added with a simple mod, which allowed one to enable or disable autoframe rate.
      ( Automatic framerate causes display to flicker at the start of movie when frame rate is adjusted, so some people do not like it ).
      5. There are reports that the original Rikomagic MK22 ROM cannot detected USB thumb drive/USB HDD and slow throughput.
      This isn't always repeatable for me but anyway the whole drivers and kernel have been replaced with a new set of drivers compiled from source.
      6. The Rikomagic Mk22 ROM is a 64-bit Android ROM. Most other available x92 ROM are running 32-bit zygote.
        HI, I have an x92 3G/32GB which is on android 6, How do I update it to android 7?
          Halo everyone i have X92 2/16. i upgraded it to V19 SAMDE I want to upgrade to samde v20 help me with link
            Okay, i updated it through sdcard to android 7.1.2 but the bluetooth is not working.I flahsed this firmware
            provided in the above post.
              Samde v.20
              https://mega.nz/#!OgtHXSzT!tdHvpEBD_...FJTG6AuDNcme6k
              You can update with latest A7.1.2..... 20171211 (reflash)
              https://mega.nz/#!OwlkEDRJ!CnLslKiCi...Zt3mX9Mbnq-oq0
              You can either install it using USB burning tool or SD Card maker.
                I get error when I try to update samde v19 to samde v20. ( Could not find 'META-INF/com/Google..,....,....)
                I think I should be on Android 7.1.2 to use samde v20 coz it a backup of a different twrp. Help me with link for X92 2/16 Android 7 rom
                  Yup v.20 is Android 7.1.2........
                  I think you should know....
                    Do you have any working link for x92 2/16 android 7 even ugoos or stock. i can only see for 3/16 in many forums
                      Check on 4pda (in OP) .....have 2 posted ....Android 7.1.2, the port of Rikomagic MK22
                      Port firmware, android 7.1.2 from Vasily_5
                        I have updated it with mk22 link everything is working fine. Thanks
                        is there anyway I can play android games from play store?.
                          Hi, How did you updated to this firmware?
                          Did you rename the file to update.zip and press the reset button by addig power to the box?
                          Or I have upload with win32 Disk Imager? Or???
                          Do you have to install anything else?
                          g947
                            download this firmware below no anyother software to download. your box should be x92 2/16
                            1-https://drive.google.com/uc?id=1H5lkvC-lDdlz_jJ-_7AuYskV7c6ypo03&export=download
                            2-download usb burn tool it comes with drivers and install it on windows (best is google youtube how to use amlogic usb burning tool.
                            3-you need a usb to usb cable.
                            no rename just extract it and load it in usb burn tool
                              Hi! I'm currently on samde v.18. on android 6..I would like to go back to stock but when i put BACK_TO_STOCK_X92_3GB_05.02.17_ROOT in the root of my usb using twrp restore from backup, twrp cant see any image..please help
                                I tried to do everything as you wrote. When I connected the box with the usb-usb cable, nothing happened. The USB Burning Tool detected the file, but nothing else.
                                There was no connection between the box and PC.
                                Is it any difference which USB port will be use during flash (I tried all four).
                                Now I am using V13 firmware.
