X92 TV Box S912, Android 6, 3/16GB, Dual WiFi, Gig Lan
Originally posted by mxqpro View Post
When you booted into Android using SCcard (without deleting kernel.img) did you see the display rotating between clock, date, temperature ?
If I could get even software rooted IMG, I would install it.
The main thing I want is ROOT
Originally posted by mxqpro View PostOne of the post you said without deleting kernel.img you said you can boot into android. Now you are saying something else.
Without deleting, it was booting straight into Android, After I deleted it started to go straight into android recovery but it goes blank for a while, showing it was trying to read something.
Don't stray into something else.
No, its just going blank for quite long then eventually boot into the normal system recovery option..
So my question was without deleting, it boots straight into Android, did you see the x92 front panel the display rotating between clock, date, temperature and others ?
I have already ****ed up. I tried to update it but now it no longer go into android. Its now booting into recovery mode. I am pretty sure I now need to install another firmware
Finally I have managed to solve my problem, I failed to install TWRP but I have managed to install 6.01 Ver with SuperUser .
Thanks guys for all your help.
The reason I think why I failed to install TWRP is my SD card or adapter. I tried 2 diff cards using same adapter but it was working.
I discovered that when I tried to upload new Software with It, it was saying Error. I eventually succeded with usb data stick.
Link for software I i have used .... https://login.gearbest.com/m-users-a...-firmware-2041
So anyone else also tried this ?
https://mega.nz/#!ud8XDbyQ!Ajpg2D7Wg...hhfkBMdPl7ws\\
It works on ROM from vasily, Android_7.1.2_PC- rooted_Vasily.img to make it display time, date, temperature and so on the front display. I don't use the stock firmware, maybe people interested can try it on this stock 7.1.2 firmware.
No installation required, just unzip everything and store it on SDCard and boot up from SDCard.
If it works, it will start with displaying 'boot' on the display, and then later the clock, date, temperature will be rotating on the x92 display.
Maybe first boot the wifi is not working. After restart, the wifi is working. That's my observation.
The file size attached its 27.5 megabytes
But since it does not write anything into your existing ROM flash storage, this overwrites is only session-based. It is not permanent. If you remove your SD card, restart, then you are back to everything in your original ROM.
Yes. It only overwrites a few important things of your installed ROM.
Ooh! got it now.
Hi everyone,
I haven't been able to keep myself updated with the recent ROMs. I am currently on Ugoos Android 6 (2016) firmware.
Just wanted to know the latest Android 7 is this: https://mega.nz/#!OwlkEDRJ!CnLslKiCi...Zt3mX9Mbnq-oq0
Right?
EDIT: Nevermind. I thought its custom ROM. I would appreciate if someone has a link to Android 7 custom ROM.Last edited by DreamB0yDani; 10 February 2018, 17:05.
There are currently 1787 users online. 1 members and 1786 guests.
