Sent from my SM-J700F using Tapatalk
X92 TV Box S912, Android 6, 3/16GB, Dual WiFi, Gig Lan
Originally posted by badmelatonin View PostI think u hv got yourself the 1st release android 7 firmware for 3gb (build 20171020). Current latest android 7 build is 20171211 & Stasio had provided the mega download link on previous post. U may want to check it.
Originally posted by MekkelRichards View Post
No, I downloaded the link from MEGA (x92 3G 171211.rar). I am currently running the version that you have just mentioned. You can also look at my screenshot. Sorry if I wasn't clear.
I think I may have flashed it incorrectly resulting in it not actually flashing. What is the process for flashing a new ROM on these things?
1) transfer only "q201-ota-root.zip" to sd card & rename the file to "update.zip". Mount/insert the sd card to box
2) reboot box to recovery mode (i am using Quick Reboot from playstore)
3) once in recovery mode do these:
- wipe data/factory reset
- apply update from EXT (select SD card & select "update.zip" file)
- wait for the update process to complete
- once completed, select "Reboot system now"
4) seat back, relax & enjoy the "hogwarts BGM boot animation".
Originally posted by zap View Post
Here you are
A quest for the adventurous
Alternative kernels for X92
(both 2Gb and 3Gb variants)
A list of changes compared to stock kernel - HERE
No reflashing required.
The kernel boots off either a USB stick or a SD card.
Copy the files for your model into the root of a stick/card, insert it into X92 and reboot with the button inside the AV jack pressed with a match.
Hold the button pressed for relatively long time (10-20 seconds). If your USB stick has an activity LED, you can release the match as soon as it starts flashing, indicating read.
If anything goes wrong, just remove the card/stick and reboot, and you get exactly your old Android without any changes.
If you like the new kernel and want to boot it without having to press the button in the AV jack, there's a instruction how.
More detailed instructions - HERE
Download - HERE
If somebody skilled with linux kernel wants to join the joy -
https://github.com/anpaza/akbuilder
Do take note that x92 is the 1st & only tv box i've owned. However i had 100% success & 0% failure by using below method so far:
I am pretty familiar with flashing ROMs on Android phones. I am assuming that performing the above steps will wipe any apps I have installed off of the stick, correct? (Asking because I have Kodi setup with a ton of features that will be very annoying to reconfigure but will do if I have to).
Originally posted by JoeDante View PostHi,
can anyone help me?
I tried to update my 3/32GB X92 with Android 7 Stock Firmware. Update seemed to run OK, but now the box will allways boot up in recovery mode.
No matter what I do, it will allways boot right to recovery. What can I do to resolve this??
Thanx in advance!
Originally posted by mxqpro View Post
When inside recovery try to find a menu which allows you to clear dalvik cache and cache. If your recovery does not have such item, you might need to find a TWRP recovery which works for your device.
Thanx, I tried that, but no use. I managed to solve the problem with a firmware image and Burn Card Maker, but every other firmware I tried besides 08052017 would brick my box and I had to reinstall everything from SD card. I have the 3/32GB box, but no other firmware worked. Can you tell me where to get the TWRP recovery? All the links on 4PDA are dead....
Â
There are currently 1643 users online. 0 members and 1643 guests.
