X92 TV Box S912, Android 6, 3/16GB, Dual WiFi, Gig Lan
Originally posted by Ndongo View Post
It's your cable
Anyway, I also changed my male2male usb cable and tried all the A7 I could found, obviously the MK22 is the most stable of them all, with only a very few bug that are not deal breakers at all !!
Now I'm gonna try the latest modded version found also a few pages back and see what good it brings .. ( https://mega.nz/#!bYEylAwS!p9LQy-C5P...RrRpGqf-lNraPI )
Thanks for everyone who posted here in this thread, there is many priceless information !!
Hi I recently update my x92 3GB box with Poison Rom from XDA everything is working very nice and very fast except front LCD clock and etc. If someone know how to install drivers or something for it . I read all pages here I found a custom kernel but it`s seems this not compatible with android 7. when I boot this kernel from sd card, front panel is working but android does not start.
I`m on android 7.1.2 Poison ROM v4.1
Thank you in advance.Last edited by inscriber; 16 June 2018, 10:58.
hi! i have just got a 32/3 gb x92 box. cme with android 7.1.2. , android security level 2017 aug.1, kernel 3.14.29, build updated to v.2018.05.07. is there any recent, update or thisis the latest? if there is, then could you link it for the 3?32 variant pls? also somtimes the screen flickers when restaring the box with the restart optin.(not power off and then on, but restart) any options for this to solve? Also i miss the notificatoin bar and the app changer menu,and the new message, email little numbers on app icons. Can you recomend a good launcher for these things to work?thNKS
Have anyone a power problem? I installed 8.2.4.2 Libreelec in internal and everythin was ok! I used 1-2 hours and shutdowned. The blue light was always there. After few hours the blue light is no more there. I tried to plug the dc again but the blue light goes on for few ms and goes fast away. Now its always flickers when I plug the dc..
have anyone a solution for this problem? Or an alternative power adapter that would work?
Originally posted by mxqpro View PostAnyone interested in trying ROM can try this one :-
This is a modded one based on x92 Rikomagic MK22 ROM. This is for 3G only.
1. The LCD panel works with displaying time, temperature, and flash activities.
2. The modified TROM launcher is reverted back to the Lighthome launcher. The TROM launcher has Russion mod embedded inside while the Lighthome is English. Also modified a few non-working panels in the launcher.
3. Supersu.apk and su are removed. Totally replaced with systemless Magisk.
4. Original automatic framerate adjustment is added with a simple mod, which allowed one to enable or disable autoframe rate.
( Automatic framerate causes display to flicker at the start of movie when frame rate is adjusted, so some people do not like it ).
5. There are reports that the original Rikomagic MK22 ROM cannot detected USB thumb drive/USB HDD and slow throughput.
This isn't always repeatable for me but anyway the whole drivers and kernel have been replaced with a new set of drivers compiled from source.
6. The Rikomagic Mk22 ROM is a 64-bit Android ROM. Most other available x92 ROM are running 32-bit zygote.
I flashed the 'stock' rom, then the modded rom. Everything was fine but didn't like the launcher. So, I downgraded back to android6, but now the status bar and navigation bottom bar is missing. How do I get them back?
Thanks in advance.Last edited by futra; 24 July 2018, 06:04.
Originally posted by TheJoker71 View PostManage to downgrade from stock 7.1.2 to 6.0.1 using stock 20170508 img firmware... Only issue i cannot upgrade to stock 20170916 firmware... Always stock to x92 logo bootscreen... X92_3gb_32gb version... Any idea?
There are currently 2653 users online. 0 members and 2653 guests.
