X92 TV Box S912, Android 6, 3/16GB, Dual WiFi, Gig Lan
    Originally posted by xbones View Post
    Thank you for the info. Just to state, that I have flashed my firmware on this device and several other TV boxes before. This particular ROM which was mentioned just a few pages back in THIS thread, was android 7 for the 2gb/16gb X92. However it's MK22 based. It boots on the X92 but videos dont play on internet, the screen goes black. This is what we are having flashing from. I download the 6.0 usb firmware update, however now my device wont get detected via USB. So i can only use img file.
    Can you recommend a working 6.0 2/16 img file that is compatable with X92 that I can just flash to get a base to use ota from on SD card?
    The stock 6.0 from May 2017 is available in the same thread on 4pda where you got the MK22 firmware.
    I also think there has been posted a link to it earlier in this thread, maybe 10 - 15 pages back.
    It is always advised to read every post in a thread before you start, so that you get a clear picture of what is possible and what not.
    There have been several comment on here that the MK22 firmware sucks, so if you had read every post you would not have made this mistake.
      I got the stock firmware, but it's zip file.. I can't flash the zip through the MK22's updater it fails. How else can I flash a zip? I tried from booting from SD Card, and it goes through the whole process then fails with error 7 like the other guy mentioned before. I'm looking for a IMG file that I can flash via usb burning tool or sd card maker.. But it has to be IMG file.. On the Mk22, we can not flash ZIP.
        Ok, I went to http://4pda.ru/forum/index.php?showtopic=773971&st=420
        download the official 7.1.2 IMG for x92 2/16. Flash in USB Tool . Success
          Originally posted by ypnos View Post
          3/32 version with 6.0android wanted to update to android 7.
          I need your help, urgently please.
          tried to upgrade via OTA (Select file) got to recovery screen, chose wipe data and then update via SDCARD but.. i get the messages attached.
          I also tried via USB stick but no luck.
          I have used the x92 3G 171211.zip
          Please advise what I am doing wrong and what i should do.
          THank you in advance,
          to whomever might have faced the same problem as i described above.
          The solution was simple but, you do need a USB cable male-to-male.
          Connected box to PC, reset, USB burning tool etc (the process described in previous posts).
          Now running 7.1.2 on custom rom.
          Worked like a charm.
          Plus, Android 7 finally give you DTS support.
          Hopefully a new updated IMG will come up soon.
          Only negative so far is the high temp: 60-89c
            What is the custom ROM you are running?
              Kodi has always been able to play dts encoded files. And Kodi consumes higher CPU.
              Other players such as mxplayer requires external codec files.
              Certain firmware has stability issue.
                Anobody can share .IMG for stock android 6.0 3gb/32gb?? Need to downgrade from 7.1.2... thanks...
                @Jancales... how did you downgrade? can you share the IMG 6.0 you used to downgrade your x92??? thanks...
                  @stasio... i saw you advice several already that TO MAKE THE CLOCK IN FRONT PANEL not showing 24hours... is just go to the settings and untick the 24hours display... can you explain again how you do it? i tried several times but still the FRONT PANEL clock still showing 24hours... thanks...
                    I haven't x92 2 gig ram 16 gig memory and it is stuck in recovery mode wonder if anybody could help me out?
                      Manage to downgrade from stock 7.1.2 to 6.0.1 using stock 20170508 img firmware... Only issue i cannot upgrade to stock 20170916 firmware... Always stock to x92 logo bootscreen... X92_3gb_32gb version... Any idea?
                        Just to clarify speculation about my poison rom and compatibillity with S912 devices
                        My rom is modified to work on any S912 device, its preserves needed files from the previously installed firmware and adds them to the ROM, thus why my rom is distributed without a kernel.
                        I have a 2/16GB T95Z and as the rom states its using the 3/32GB /system partition ported to work with all variants of S912 chipsets.
                        everyday im working more and more towards a completely universal ROM for AMLogic devices.
                        I have also completely ported a rom from an S905x to the device without any bugs.
                        so as ive told the AMLogic community before, having a developer with the abillities i do you can expect an earthquake of changes.
                        first was my poison rom, then came an init.d implemention, then came my amlogic flash tool with the abillity to port custom recoveries to any amlogic device, now its my completely rebuilt Amlogic tools that are open source.
                          Can you port this Dune Neo 4K S905X firmware to X92?
                          To use Google Drive, you need to use a supported web browser. Learn what a browser is, which browser you use, and how to update to the latest version. Option 1: Find the update for your browser To
                            I nice person has posted me an S905X device,so when it arrives, sure i can!
                              Many thanks! Please notice when it's done!
                                Hey guys, I have just bricked my device while trying to install "X92-MK22Plus-Android-7.1.2-01.09.2017-MOD-051117-6." using sd-card. Now my device doesnt turn on AT ALL, only the blue X92 that lights up !!
                                I'm trying to unbrick it using USB Burning tool, but I cant find a working stock android link with .img format !! either 6 or 7 .(even in 4PDA forum). So I tried with the MK22PLUS img itself, but the progress never passes 4%, and then I hear the usb disconnection sound, is it because it's not stock android or I need some usb drivers to be installed ??
                                So can someone please provide an .img stock android link ?? And also help me out find if I'm doing something wrong .. as this is my first time using such tools !?
                                I did a lot of reading but things don't always go as described !!
                                Please I'm relying in you ..
                                edit : my box is a 3/32 and before brick I was on android 6 latest official update I think .
