Alfawise H96 Pro+ Android 6.0, 3/32GB DDR3, Gig Lan, Dual WiFi and BT
    Click image for larger version  Name:	WITB.jpg Views:	1 Size:	123.1 KB ID:	610438
    Amlogic S912
    3/32GB DDR3 Ram
    Android 6.0
    Dual band WiFi: 2.4G plus 5.8G BT
    1000M LAN
    Top View of PCB on a thin alloy heat sink stuck on will see how it goes
    Note 2 USB ports next to TF card slot
    I also see some LEDS and there is Cut out in the lid case you case see to the left, this could be interesting.
    Click image for larger version  Name:	Front.jpg Views:	1 Size:	209.3 KB ID:	610443
    Click image for larger version  Name:	usb1.jpg Views:	1 Size:	221.0 KB ID:	610444
    Note TF card slot with no exposed USB Port, must be like those Vents they often forget about
    Click image for larger version  Name:	tf.jpg Views:	1 Size:	200.4 KB ID:	610445
    Click image for larger version  Name:	ports.jpg Views:	1 Size:	228.8 KB ID:	610446
    There was no Fancy Light show with this Unit, just a Blue LED and an option to switch of on the lower Task Bar
    First impression, I find you can usually tell with first switch on and start to set up with Apps etc, looking good, easy setup, into Google Play updated all the bits required,
    no lag noticed, all installed very smooth so far so good.
    More test and Benchmarks to come Build Version 20161101 so fairly up to date.
    Alfawise H96 Pro+ Does have proper root with SU, and does not appear to me to much bloat,
    Temp is hovering Mid 40c I think A bigger block of alloy maybe required, but if its not broke not gunna fix it.
    Gearbest
    MTC
    Waiting for my box to arrive, Trebor, I have read the manufacturer has back door access to the box? Is that Samsung nand or rom?
      Spectec Ram, Samsung emmc,
      Tell me more of this back Door why cant they use my front door like normal People
        being almost Christmas why not use the chimney !
        Bugs are Sons of Glitches!
        JustMe
          Even better, a bit of HO HO HO...how nice
          Malwarebytes removed some junky fake update up when I fist ran it yesterday, could have been that.
            More Bench test of the Alfawise H96+ Pro
            http://browser.geekbench.com/v4/cpu/1088426
            PCB is the same as the 4k Pro different emmc if my memory is correct. and maybe other stuff.
            Unit working well no major Meltdowns, into Low 70's when pushed with 3dmark.
            Does appear to be rather snappy, and nothing much else at the present,
            No backdoor bandits found as yet , front door is always open, bring a beer and we can have a chat.
            Thanks to Gearbest and DHL supper fast as usual
            It works its ok...
              1.5ghz only ? not 2.0ghz ?
              Sent from Note3 N9005.
                Sami_b This is a known mistake in early S912 literature, or AML got caught fudging the numbers. Either way, clock doesn't determine everything.
                  Ummmm mistake is when you didnt know you fudged the printing.
                    I'm in a good mood and I was trying to be kind.
                    But, yep, not many excuses for still seeing it.
                      Printing you have a problem with etherney, it's a new thing I am told.
                        THanks Trebor, on the second pic, their is white conector. What is its use? If it's a spare can a fan be connected?
                          I recall it's part of the LED show on another unit unsure the voltage present but yes you could
                            Thanks Trebor, how is this box compared to beelink gt1?
                              Looking at numbers that can and don't really mean a lot but gives and Average.
                              3/32 would have some advantage over a 2/16 unit you would think,
                              Beelink does have a better Heat Dissipation than this unit but an easy to mod if needed.
                              They're about the same in running apps etc as tested give or take.
                              Like most of the S912 I have tested they all have their moments of Good and and not so good
                              This did appear to be a litte more zipper when loading and doings things(and came with a free backdoor)
