Alfawise H96 Pro+ Android 6.0, 3/32GB DDR3, Gig Lan, Dual WiFi and BT
    Trebor found this gearbest, could this be used with the connector?
    Just US$3.06, buy Colormix Cooling Kit for Raspberry Pi 3 / 2 / B+ online shopping at GearBest.com Mobile.
      It may, I would tend to go the other way, fans in boxes make noise, collect dust,
      A beefier heatsink and attached to the CPU with the correct glue or paste would be better I feel if needed
      It has Vents underneath just sitting on a laptop cooler would be easy, they're cheap also under 5 bucks.
      As the Box does not have a lot of top side ventilation you would have to drill holes using a fan as you suggested.
      Heat is not a big problem now since the CPU's are running true speeds, had one player hitting the 90's now 50 idle 70 working should be fine.
      I see I forgot to up a picture of the Base of box
        Yes and may be cheaper just using glue because Vents cost a fortune thats why so many boxes dont have any. Gota keep costs down.
          Thanks again Trebor, this box has great back door access unlike other boxes. I've got spare laptop cooler, which I can use.
            I have order this box from Gearbest 12 days ago and they are still processing the order. Their reduction code did not work for me. The item was in sale and the code increase the price instead of decreasing it...
            This TV box is suppose to be in stock.... Will I get it for Christmas ? Humm... Not Happy.
              Where I can find official support for this product, like firmware update and so on?
              This tv box can or cannot read external subtitle?
              Also, can read external 1-2TB HDD formated NTFS?
              Thx,
              Adrian
                The Subtitles would be up to program used, there are many.
                Working well with my 1TB portable Seagate HDD.
                Cheers
                  Thanks a lot. But...your hdd its NTFS or FAT32?
                    NTFS
                      Perfect! I just place the order.
                        Originally posted by trebor View Post
                        Even better, a bit of HO HO HO...how nice
                        Malwarebytes removed some junky fake update up when I fist ran it yesterday, could have been that.
                        Hi Trebor, tryed to install malware bytes from play store but just says pending, it shows its a app for mobile. Is it the non standard update app you deleted?
                          The one related to this icon on desktop.
                          As long as you did not run this thing, you should be ok but if you ran you may have some weird stuff happening
                            [ATTACH=CONFIG]n611954[/ATTACH]
                            That's the first thing I did was to run it, would it be best to do a fresh start?
                              Yep do a reload/recovery may work, format wipe data
                              Set up playstore,
                              Dload malwarebytes and run see what you find
                                Set up playstore,
                                Thanks Trebor, will do
