Alfawise H96 Pro+ Android 6.0, 3/32GB DDR3, Gig Lan, Dual WiFi and BT
Originally posted by wwmoggy View Post
what temp where getting before changing the heatsink. I have a heatsink here that is 12mm high would it fit
I am using a folding notebook cooler fan plugged into a usb charger . and vent holes drilled top and bottom of case stock heastsink and my temp is 50 c never goes over 56 .
I will have to measure the chip my heatsink is 30 x 30 x11
edit after sitting over night temp is 44C goes up 50c watching a 1080 movieLast edited by wwmoggy; 11 December 2016, 17:08.
K did little searching theres 2 versions of The Rbox pro . oneuses the same motherboard # Q9377 and has the 3gb + 16gb and had a firmware update http://blog.geekbuying.com/index.php...ware-20160927/
http://www.mediafire.com/file/6cqi9z...c-20161118.rar
Hi everyone, I'm new here and so glad to find this forum. I've been using this H96 Pro + for three weeks now and very happy with it.
The only issue now I have problem with YouTube app, the one I downloaded from PlayStore. It's been working well until few days ago when it fails.
The video loads successfully but it just won't play.
I've tried to solve the issue with uninstall then reinstall, delete the caches/cookies but it remains the same.
The only thing I haven't tried is factory reset.
Anyone here face similar problem?
There are currently 2587 users online. 1 members and 2586 guests.
