Alfawise H96 Pro+ Android 6.0, 3/32GB DDR3, Gig Lan, Dual WiFi and BT
Hi guys, I've made some cuts to the casing to get the extra 2 usb ports. My problem now whenever I use this port for external hardisk (the big 3.5" one powered by an adapter), the screen will go blank. Using a thumb drive will not give similar problem.
Is it something to do with the insufficient ampere frorm the power supply? What if I replace the adapter with a bigger amperes? ThanksLast edited by nikrizal; 15 January 2017, 04:04.
Guest
I have H96 Pro+. When watch movies in Kodi 720p or 1080p then all ok and movie run very smoothly. But when watch movies in 4K, example in Silent Hunter, then movie has sound but no picture. Some movies working correctly like The Fifth Element. When disabling amcodec for acceleration, then video working but movie dont run smoothly anymore!
Heya,
Sommerman, try looking into this potential tool for sustained fix http://freaktab.com/forum/tv-player-...-s912-firmware
Not all 4k content is coded the same. Try several different UHD content movies/demos. It may help correct the codec/ frame rate problem.
Quick fix, install/ re-intall Mx Player with the * AC/DTS Codec* bundle ..reboot and try kodi or SPMC again.
G-Luck
Reap
There are currently 2275 users online. 1 members and 2274 guests.
