All, I see on top right corner I see some cleaner, whenever i click on that it always shows "0 processes, o cleared", whereas I know there are certain apps open and running. Is this the behaviour or I am missing something?
Alfawise H96 Pro+ Android 6.0, 3/32GB DDR3, Gig Lan, Dual WiFi and BT
Originally posted by trebor View PostThose are fixed, you can find custom launchers on Google Play and set up how you wish.
I think the cleaner is not working 100% if at all, again many can be found on google play.
Which will be One click good cleaner. Would I get KODI icon as part of Big Icons in any updates? My OTA always says "No updates found".
Any specific Launcher which should work best with H96 Pro+? Any recommendations are always welcome.
Originally posted by trebor View PostThose are fixed/cannot be moved.
As there are many options to be found on Google,
Launchers
Cleaners
All are fairly easy to install and unistall have a look
OTAa updates only appear every now and again so you much be upto date.
Hi, I am not able to connect to MIRACAST/DLNA via my mobile. I am able to see the device and when click connect, it take ages and nothing happens. Am i missing something here?
Also, Google apps Android TV Remote Control (https://play.google.com/store/apps/d...v.remote&hl=en) were not able to detect my device even on same network and Bluettoth turned ON. Do i need to do something to make this device detectable like Android Box.
trebor Please help on your expert guidance.Last edited by abhishekbafna; 31 March 2017, 16:53.
Originally posted by muncheno View PostMany devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by abhishekbafna View Post
trebor I have exactly the same but instead of KODI, there is Netflix BIG ICON and KODI sits where your Google play store app is in snapshot.
Originally posted by abhishekbafna View PostHi, I am not able to connect to MIRACAST/DLNA via my mobile. I am able to see the device and when click connect, it take ages and nothing happens. Am i missing something here?
Calling experts and advanced users...
Hi guys, I'm very sad My alfawise h96 pro plus,not start anymore, it stuck in red light...any solution?
I have only replaced superuser (uninstalled with TiBu) with superSU before, after restart and it block on H96 Pro+ yellow logo, so I off box and not more restarted
Now I tried flash superceleron v2 Rom with SD card method, but when I hold reset button and plug in power nothing happens.... Tv box stuck in low red light and not responding.... What i can do? Anyone e have same issue??? Please help me
I used it only 3 times
There are currently 3478 users online. 1 members and 3477 guests.
