Alfawise H96 Pro+ Android 6.0, 3/32GB DDR3, Gig Lan, Dual WiFi and BT
Originally posted by adytzu View Post
Good advice! Thank you so much!
I just bricked my box, so, who read this, DON'T MARK ERASE BOOTLOADER!!!!!
Booting this I found inside of the log of recovery "E: Bad bootloader arguments: 'null'" and later also some mount errors. So it's clear that the update requires this setting.
Got you full progress with this update? So maybe this ROM doesn't match your hardware really.Last edited by Endur; 12 June 2017, 13:46.
Originally posted by wwmoggy View Postmake sure you are using 4gb or 2gb sdcard or update will not complete
Originally posted by trebor View PostI recall it's part of the LED show on another unit unsure the voltage present but yes you could
[ATTACH=CONFIG]n610505[/ATTACH]
Originally posted by trebor View PostThere was no Fancy Light show with this Unit, just a Blue LED and an option to switch of on the lower Task BarLast edited by Shimon; 08 July 2017, 19:15.
Do all Alfawise boxes from gearbest shipped in June/July come with ddr4 board or it it random luck between ddr3 and 4?
So for best user experience is to have ddr3 on android 6 with Kodi 16.1 as platforms?
I also see kodi fork named spmc 16.7 here? Is this better then stock kodi 16.1 or do you guys run stock kodi 16.1?
Semper Media Center (SPMC in short) is a android-minded fork of Kodi, by the former Kodi android maintainer, Koying
What do you guys make of this fork of kodi 16.1?
LibreELEC 7.1.0 / Kodi 16.1 for the Hub by wrxtasy
http://wetekforums.com/v/index.php?p...-by-wrxtasy/p1
What's the bluetooth version on this board and does it work with all/most bt game controllers?
Anything i should do from get go when i receive this box to save myself from few headaches?Last edited by Rango; 30 June 2017, 00:24.
There are currently 2263 users online. 1 members and 2262 guests.
